Results 1 to 6 of 6
Thread: JK Suspension Advice
  1. #1
    Fresh Catch Shaun_E's Avatar
    Join Date
    Apr 2015
    Location
    Nashville
    Posts
    3
    Hey all-
    Need some advice/help with my "Frankenlift". I have a 2012 JK Sport (manual) and don't do much extreme off-roading but looking to clear my 305/70/17 (34") tires a little better and get rid of the factory rake. Now I don't mind doing the work myself and am perfectly capable of doing it but suspension has always been a little foreign to me (mostly just how everything works together).
    My current coils are 14/55. I just got some 17/58 coils from a buddy that bought a new JKU and added a coil lift. I also bought a 1.75" leveling kit (1.75 front, .75 rear). The leveling kit has bumpstop extensions for front only. Lastly, I bought some Rancho RS9000 shocks (RS999329/RS999330) for 3" lift in front and 2.5" in rear.
    So my questions. Knowing there is no guarantee how much lift (if any) I will get out of the new coils.
    Will I be ok with the longer shocks?
    Other than the front bumpstop extensions that came with the kit (they're maybe an inch), is there any other thing I should consider as it relates to bumpstops, i.e. longer, rear, etc.?
    Finally sway bar links. I had considered buying new rears for the front since they are longer. Is this necessary?
    Anything else I'm not thinking of I should consider? Any help at all is much appreciated!
  2. #2
    Addict catahoula's Avatar
    Join Date
    Nov 2011
    Location
    Oregon
    Posts
    8,388
    Well I changed from 14/55 to 18/59's then added TF leveling puck kit. 2 1" pucks in front and 1 1" in rear. Running 255 stock Rubicons take offs and this is what mine looks like. I am pretty sure I could run a 35 and might have to trim a bit.
    “Dogs are our link to paradise. They don't know evil or jealousy or discontent. To sit with a dog on a hillside on a glorious afternoon is to be back in Eden, where doing nothing was not boring--it was peace.”
    “Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do...
    Explore. Dream. Discover."
    "Take a compass, because it's always awkward when you have to eat a friend."
  3. #3
    Join Date
    Apr 2015
    Location
    Nashville
    Posts
    3
    Quote Originally Posted by catahoula View Post
    Thanks man. Looks really good. I'm fairly certain you could run 35s on that setup with no issues. I've run 34s on mine with aftermarket wheels on a bone stock suspension with no issues at all.
    I'm mostly concerned with the longer shocks I bought and if they'll be ok to run (not knowing exact lift height I will achieve). Also if I should get longer swaybar links up font?
  4. #4
    Join Date
    Nov 2011
    Location
    Oregon
    Posts
    8,388
    I'm using rubi shocks and links from tf leveling kit. You could get 2" longer shocks possibility or run adapters. I have some and not used yet.
  5. #5
    Join Date
    Apr 2015
    Location
    Nashville
    Posts
    3
    Thanks, man. I ordered some Rancho shocks for 3" lift up front and 2.5" rear. Was just curious if they may be too long and/or if I just need longer bumpstop extensions? Think I'll be ok but just wanted to see what folks on here thought. I appreciate the help.
  6. #6
    Knows a Thing or Two aldaman's Avatar
    Join Date
    Oct 2012
    Location
    Hawaii
    Posts
    980
    Swaybar links - The rears should be fine. As for the front, see if you can get an extra set of stock rears ones for cheap or free and use them for the front. Preferably the angle should be slightly above parallel or parallel at the least.
    Longer shocks - One method to see if the shocks are too long is to cycle your suspension and see if you are getting too much droop from those shocks. (I.e. are your coils about to unseat/come off, are your ABS or brake lines over extended, etc)
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
