Page 1 of 178 1231151101 ... LastLast
Results 1 to 10 of 1778
Thread: My life with a Brick
  1. #1
    Addict JKbrick's Avatar
    Feb 2013
    Leo, Indiana
    7,844
    I'm really close to giving up on this damn thing. I've been fighting death wobble since July. It is a 2009 2dr rubicon, 13,500 miles on it now. I had a JKS lift that ended up giving me 3 1/4" of lift. Flipped my drag link, raised both stock track bars. All Currie adjustable control arms except front uppers. Wheel spacers and stock rubicon tires and wheels. It never looked great lifted with stock tires so I never drove it much and just drive my work truck. It all started in July when I had my tires balanced and I rotated them. That was my first death wobble, I could tell the trackbar bolt had moved by the paint scratched away from the hole. Had the tires rebalanced and put them back to original location and then no death wobble but a sensation of my front pass side tire felt like it wanted to fall off when I hit a bump. Got so sick of it I took my lift off and put steering and track bars back to stock locations. I even had the local dealer give me a set of 16" steel wheels with the little car tires on them brand new to eliminate the problem being a tire. Yesterday I was anticipating a test drive like driving a new jeep but 2 miles down the road the f'ing thing had death wobble back, so it got worse not better. My son came over and turned the wheel for me and nothing seemed to move at all that shouldn't have. He pried up and down on the tires and there seemed to be no movement at all. So I'm down to throwing money at parts in hopes I guess the right ones or just parking it till I hit the lotto. So damn frustrated.
  2. #2
    Oct 2012
    SoCal
    31,584
    Factory ball joints? Do you have gussets? Unit bearings stock?
    2012 Dozer JK
    -Dynatrac PR44/Rubicon Rear
    -Nitto 37” Trail Grapplers
    -Rock Krawler 2.5” Lift
    -ATX Slabs
    -Warn VR8
    -EVO Armor/Bumpers
    2012 Billet Silver JKUR
    -EVO DTD front and rear
    -Dynatrac PR60/PR80
    -EVO High Clearance Long Arm
    -Nitto 40” Trail grapplers
    -KMC Machetes
    -Warn CTI 9.5
    -EVO Armor/Bumpers
    1975 DJ5
  3. #3
    Feb 2013
    Leo, Indiana
    7,844
    Yes factory ball joints unit bearings and steering and c gussets
  4. #4
    Old Timer Clutch's Avatar
    Dec 2015
    STL metro
    2,769
    When did you put the lift on? Did you have your tires balanced a 2nd time? Is the bolt hole in for your front track bar wallowed out at all? Are you sure your unit bearings and ball joints are still good?
    Sorry for all the questions, I know death wobble sucks! I had it over the summer and it turned out to be a combination of a loose front trackbar, busted steering stabilizer, and caster being too low.
    I sincerely hope your find the problem.
  5. #5
    Nothing but a Thing desertrunner's Avatar
    Mar 2013
    Great Falls, MT
    2,131
    I feel for you! i had mine tore apart for 3 weeks bumming rides to work because i couldnt drive it due to death wobble.
    Mine had a lot more miles on it than yours but ill at least tell you what i found with mine
    Idk if i wasnt doing it right (im sure that was the case) but when prying up and down on the tires it didnt look like my ball joints were moving at all but i Bit the bullet and swapped them out for pro steers, when i pulled the stock ones out they basically fell apart in my hand they were so shot. What size tires are you running? I know the stock ones are cheap and could get wore out pretty quick.
    I didnt have a drag link flip at the time so i went ahead and did that and when i did the joint that connected my drag link to my knuckle was shot as well might be something to look at?
    And i had my caster about 2* off what it should have been
    Once i fixed those my Death wobble went away, I didnt mess with my unit bearings although i think i should have but i ended up selling the jeep before i got to it.
    12' 2dr Gecko Sport 6 speed
    PR44, ARBs, 4.88s, 35 spline rear, Adams 1350 Front & Rear, Rubi T-case, Rubi sway bar + Evo no limits, Evo armor & skids, 37/13.50" Cooper STT Pro, Evo 2" plush / OME med duty springs
    ***SOLD*** 08' JKU Rubicon 6-speed Stone White, 3.5" RK lift, 37" KM2s and lots more.
    ***CURRENT DD*** 16' F150
  6. #6
    Feb 2013
    Leo, Indiana
    7,844
    Quote Originally Posted by Clutch1981 View Post
    Put the lift on in 2012, redid the balance and unrotated them back to where they were, I've been looking at replacement track bar bushings and hub bearings on rock auto today, none of it seems bad but something sure is
  7. #7
    Feb 2013
    Leo, Indiana
    7,844
    Quote Originally Posted by desertrunner View Post
    I have a set of used Dynatrac ball joints I got from a guy on here a couple years ago I was saving for a pr44 housing, I guess I'll throw them on and replace everything else if it seems bad or not. What a pain in the ass
  8. #8
    Feb 2013
    Leo, Indiana
    7,844
    Both of you mentioned caster but I think mine was right on, since I took my lift off I'm going to throw my stock control arms back on for now
  9. #9
    Mar 2013
    Great Falls, MT
    2,131
    Quote Originally Posted by JKbrick View Post
    It was kinda a pain in the ass yeah but i did it in my garage in half a day with a rented ball joint press from Napa or Advance AP and in my case it was worth it. I did have to improvise a bit with some random hardware i bought at lowes to make the BJ press work with the Pro Steers if i had to do it again i would just buy their little $12 washer kit
    Right i dont think that was really a factor in my case it was just something else i found while tearing apart my front end.
  10. #10
    Feb 2013
    Leo, Indiana
    7,844
    I bought an Astro Pneumatic ball joint press and the washer kit from Dynatrac when I got the prosteers so hopefully I have everything. Waiting to hear on a stock steering knuckle I'm going to install to replace the one I drilled when I flipped my drag link
