Close
Results 1 to 3 of 3
  1. #1
    Fresh Catch 671JKU's Avatar
    Join Date
    Apr 2015
    Location
    Guam
    Posts
    27
    Cam Position Sensors
    Hafa Adai From Guam!!. Recently had my check engine light come on and when I checked the DTC code it said my Bank1 cam position sensor was reading slow. Anyone encounter the same or similar problem? Thanks for your time guys.
  2. #2
    Knows a Thing or Two Judesign's Avatar
    Join Date
    Mar 2015
    Location
    San antonio
    Posts
    863
    I usually try to avoid firing the parts gun at a problem instead of figuring it out but this sensor is around 20 bucks and held in by one bolt. I'd just change it out and reset the code.
  3. #3
    Join Date
    Apr 2015
    Location
    Guam
    Posts
    27
    Thanks Bro but the cam sensors for the 2012 model are around 60 to 70 some bucks. It's a weird issue tho and was wondering if it's common. Hanks for your time.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
