Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Race radios
  1. #1
    Nothing but a Thing RockinAZJK's Avatar
    Join Date
    May 2016
    Location
    Waco, Texas
    Posts
    1,399
    Race radios
    I know it's probably only a select few that run race radios along with a cb. But for those that are:
    Where do you have it mounted?
    How do you have the second antenna mounted?
  2. #2
    Hooked g00se04's Avatar
    Join Date
    Jan 2013
    Location
    Raleigh ,NC
    Posts
    116
    i know some people run the evo corners and use the tabs to mount antenna's on either side.
  3. #3
    Nothing but a Thing highoctane's Avatar
    Join Date
    Jan 2012
    Location
    Chambersburg, PA
    Posts
    2,090
    I just use a handheld Baofeng radio. It works great when wheeling with a group. The handheld race radios are nice because they seem to be much more clear than cb due to the fact that not everyones cb is installed properly and tuned to transmit and receive optimally. There are many channels to choose from too when you run into the problem of other radio traffic on common cb channels. I have not used one to transmit longer distances beyond a 1/2 mile though, and haven't needed to.
    https://www.amazon.com/dp/B01J2W4JUI...=IXRDN9XQRT9BR
    You can get external antennas, handheld external mics (cb type mic), bigger batteries, and cigarette lighter power chords for it too.
    2015 Anvil Rubicon Unlimited
    Evo Mfg Double Throwdown suspension w/Evo Lever
    Evo Mfg high clearance long arms
    Evo Mfg PR60 high steer w/PSC hydraulic assist
    Dynatrac ProRock XD60 front axle
    Dynatrac ProRock 80 rear axle
    ARB lockers & 5.38 gears
    JE Reel 1350 front/1410 rear driveshafts
    Evo Mfg rocker/corner armor/bumper
    17" ATX Slabs & 40" Nitto Mud Grapplers
    Proud to be one of Uncle Sam's Misguided Children 2001 - 2010. Semper Fi
  4. #4
    Been Around the Block Sullivan's Avatar
    Join Date
    Sep 2014
    Location
    Chicago's South Side Irish
    Posts
    360
    Just switched to race radios. I have a handheld icom for right now but going to be pulling the trigger on a mobile 50watt unit shortly. So much better then CB radio.
    I think mine will either be mounted to the passenger side of the center console or I will have a custom bracket made that mounts it on the roll cage. Not sure yet
  5. #5
    Old Timer Clutch's Avatar
    Join Date
    Dec 2015
    Location
    STL metro
    Posts
    3,151
    Can race radios transmit to and from cb's?
  6. #6
    Hooked Modit's Avatar
    Join Date
    Apr 2016
    Location
    Las Vegas, NV
    Posts
    110
    Quote Originally Posted by Clutch1981 View Post
    No, CB (Citizens Band) is a different frequency range.
  7. #7
    Been Around the Block uberc4's Avatar
    Join Date
    Aug 2015
    Location
    Arizona
    Posts
    479
    Race radios
    I have a Baofang radio as well. It's awesome! A fraction of the cost of a CB radio, but the kicker is everyone needs one in your group.
  8. #8
    Join Date
    May 2016
    Location
    Waco, Texas
    Posts
    1,399
    My dilemma is I have my cb mounted above the rear view, and that's really the only place that I can find to put a radio (until I get a cage that is.). My race radio is larger than my uniform cb and just a tad smaller than a full size cobra 29. I run my cb for jeepin and the race for pits and chase for utv racing. Right now I have my race radio set up so I with terminal rings so I just quick attach it to my battery, run the wires out the side of the hood and set the radio on my passenger seat and then use a bolt on mount to the rear frame with the bumper off. Not practical but it works for race day. But I would REALLY like to have it mounted full time
  9. #9
    Hooked woof359's Avatar
    Join Date
    Apr 2016
    Location
    iowa
    Posts
    151
    driver and passenger
    ive been trying to find a radion where I can talk to my passenger with the top off at speed, and maytbe still both hear the cd player too
  10. #10
    Join Date
    Oct 2012
    Location
    Utah
    Posts
    1,883
    Quote Originally Posted by RockinAZJK View Post
    I made a mount for the main part of the radio( detachable head on my 2 meter) to go under my passenger front seat. I then ran a cord to my nav unit and will build a mount to go just above the nav unit. I don't have the head officially mounted yet. Here is a picture of how I mounted it under my seatIMG_1480053823.023612.jpg
    I ditched my CB and ham mount on the back of my rig. I recently moved both antennas up just off the side of my hood so I can use my hood as a planeIMG_1480053919.238400.jpg
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
