Results 1 to 5 of 5
Thread: 2001 Jeep Wrangler Sport 4.0 liter
  1. #1
    Fresh Catch Creekcrawler's Avatar
    Join Date
    Dec 2016
    Location
    US
    Posts
    4
    When I start my Jeep the oil pressure is normal. After it has warmed up a bit the oil pressure drops some and when u pull up to a stoplight the oil pressure drops to just barley above 0. When you pull up somewhere and shut it off, then when its started back up I have no oil pressure at all and a check gauges light is on and a beeper going off. There is no peaking or knocking noise going on in the engine and it gets a lower than Normal oil pressure reading.
    Anybody had this problem and know a fix for it?
    Sent from my SAMSUNG-SGH-I547 using WAYALIFE mobile app
    Attached Images Attached Images
  2. #2
    Nothing but a Thing Judesign's Avatar
    Join Date
    Mar 2015
    Location
    San antonio
    Posts
    1,120
    Welcome to WAL.
    Could be major like bad main bearings or something easier to fix like a faulty oil pump.
  3. #3
    Caught the Bug tdans's Avatar
    Join Date
    Apr 2016
    Location
    Logan UT
    Posts
    55
    I know the oil pressure senders get clogged and stuck all the time. I would replace that before you get too crazy.
  4. #4
    Fresh Catch kbsvo2go's Avatar
    Join Date
    Apr 2014
    Location
    East Tennessee
    Posts
    24
    I had the same problem on my sons 02 TJ. I removed the sending unit and threaded in a direct direct reading gauge to verify if I actually had oil pressure. My pressure was good on the direct reading gauge. I replaced it with a aftermarket sending unit and the problem came back within a week. I bought a sending unit from the dealer and it's been good for over a year now.
  5. #5
    Join Date
    Dec 2016
    Location
    US
    Posts
    4
    I appreciate everbodys response to my question. I had already bought an aftermarket sending unit and nothing changed. Im going to have to do some more checking though because I've been having a miss.
    Found today that I have very little compression on #5 cylinder.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
