Results 1 to 8 of 8
Thread: 2002 Tj new clinking noise after replacing Clutch and Master Cylinder and Slave.. Hel
  1. #1
    Fresh Catch Mac2011JKU's Avatar
    Mar 2016
    Homestead, FL
    6
    So I personally just finished replacing the Master Cylinder and Slave, Clutch, and Clutch Release Bearing. After driving it for no more that 20 miles there is a predominant chattering noise coming from the Bell Housing as well as a smell. I didn't leave it on long enough to tell if it was the smell of the clutch. Vehicle drove fine for the 20 miles. I plan on dropping the transmission again and figuring it out. I am just not sure what to look for!!! This is the first time I have ever done this job so if anyone has any links, videos or Ideas please let me know!!!!
    NOTE: the reason for replacing everything was due to a noise that I found out later being the Clutch Release Bearing clip snapped and the Spring Clutch Lever That the previous owner never reinstalled was missing which most people don't know it exists.
  2. #2
    Hooked kep01's Avatar
    Nov 2015
    tennessee
    126
    Throw out bearing, I went through 2 new ones before I got a good one. Make sure it's all steel not a plastic housing with steel insert.
    Sent from my KYOCERA-E6560 using WAYALIFE mobile app
  3. #3
    Mar 2016
    Homestead, FL
    6
    Quote Originally Posted by kep01 View Post
    With the transmission installed and the slave uninstalled, I can move the Lever freely with no tension at least 2inches. Sign of release bearing installed incorrectly?
  4. #4
    Nov 2015
    tennessee
    126
    That's what I would check. It shouldn't have alot of free play
  5. #5
    Nov 2015
    tennessee
    126
    Quote Originally Posted by Mac2011JKU View Post
    Check that the sleeve that the throw out bearing rides on hasn't broke. That's what caused my second one to come apart.
  6. #6
    Mar 2016
    Homestead, FL
    6
    Will do! I will keep you updated
  7. #7
    Nov 2015
    tennessee
    126
  8. #8
    Mar 2016
    Homestead, FL
    6
    I ended up replacing the clutch to a CenterForce Stage 1. The Luk was just a very soft clutch from what I had prior. Frustrating. But lesson learned.
