Close
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Caught the Bug Kaylinator's Avatar
    Join Date
    Jan 2015
    Location
    Gas City, Alberta
    Posts
    94
    Quote Originally Posted by WJCO View Post
    Possible a thin heat shield or something somewhere.
    Definitely "something somewhere." Would check that first.
  2. #12
    Fresh Catch
    Join Date
    Jan 2013
    Location
    Ontario
    Posts
    49
    when you did the lift, did you put a cv shaft into the front, it maybe the cv joint, centering ball going out. other thing is the front axle gears going out due to a bad bearing in the carrier.....
    can you give any other info, like does it seem to come from the drivers or passengers side more...
    Present Jeep:
    2013 JK Unlimited, 35 GY Duratrac's, AEV front bumper, Warn winch, Rancho 9000, RE 2.5" spacers for now.
    Past Jeeps:
    2015 JK sport 2 door, stock
    1999 TJ, 4" currie system, Dana 44's lockright's, 33" Mickey Thompson MTZ, warn winch custom front, rear and side rails. flat flares etc.
    1994, YJ, 4" procomp springs, dana 44's lockrights, 33" BFG Mud's warn winch, and TJ flares
    1987, YJ, 2" custom leafs 31" Cooper MT
  3. #13
    Caught the Bug GatorSchop's Avatar
    Join Date
    Jun 2016
    Location
    Los Angeles
    Posts
    59
    Quote Originally Posted by T.McD View Post
    No cv driveshaft. But I think it is coming out of the front dif. I was checking it this weekend and after putting it into 4H and trying to rotate the driveshaft I got just a tit hair of give and I think that might be the problem. Also noticed a small leak coming out of the pumpkin in the rear where the driveshaft meets the dif. Could be the start of blown seal. If it is then I guess I am upgrading to a D44 sooner than I planned. I was just trying to have the D30 last as long as possible so I could save up some money for a summer build.
    -Gator
    Instagram: american_cherokee
    My build thread:
    ThatAmericanXJ Build
    https://r.tapatalk.com/shareLink?url...1&share_type=t
  4. #14
    Nothing but a Thing Gadget's Avatar
    Join Date
    Aug 2014
    Location
    Pennsylvania
    Posts
    1,698
    I had a pinion bearing do something similar, during the replacement I just went ahead and had all the bearings, seals replaced in both axles.
  5. #15
    Been Around the Block XJADDICTION's Avatar
    Join Date
    Oct 2016
    Location
    TN
    Posts
    327
    Just replace pinion seal and save for your D-44. Very cheap and easy fix
  6. #16
    Join Date
    Jun 2016
    Location
    Los Angeles
    Posts
    59
    Quote Originally Posted by XJADDICTION View Post
    That does sound like a way better idea at the moment. Haha
    -Gator
    My build thread:
Posting Permissions
  • You may not post replies
  • You may not edit your posts
