Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Clayton Off Road entry level 3.5" lift and JK trouble shooting
  1. #11
    Fresh Catch
    Join Date
    Sep 2016
    Location
    Michigan
    Posts
    5
    Quote Originally Posted by MR.Ty View Post
    Welcome to WAL!
    Just to be clear, are you saying that by just placing your front sway bar links your body roll went away?
    No, I replaced the Rubicon electronic sway bar with a stock one piece traditional sway bar. That is what made the body roll go away. In addition I installed the Quicker Disconnects so I would still have the ability to disconnect the front sway bar if I wanted.
  2. #12
    Token East Coast Guy MR.Ty's Avatar
    Join Date
    Apr 2014
    Location
    South East Georgia
    Posts
    6,415
    Quote Originally Posted by Unloyalsweatsuit View Post
    You had a lengthy post so I don't remember but did you take the sway bar motor apart and see if there was anything broken on the inside of the disconnect assembly?
    2014 JKUR "Stumps"
  3. #13
    Fresh Catch
    Join Date
    Sep 2016
    Location
    Michigan
    Posts
    5
    Quote Originally Posted by JeepJeep75 View Post
    I made it through, then blacked-out... I think the OP said all Rubicon equipped jeeps are no good.
    hahaha just want to put it out there that I did not mean to imply that all Rubicon equipped jeeps are no good... its amazing how capable these vehicles are and I absolutely love driving mine. My disappointment/frustration was solely directed toward the failure prone electronic sway bar disconnect and how much play there was in that system. I am a recent, first time wrangler owner and do not know anyone else with one so I'm finding out this kind of quirky/problematic stuff as it happens...
  4. #14
    Join Date
    Feb 2013
    Location
    Wahiawa, HI
    Posts
    4,657
    Curious, why didn't you just replace the motor with the EVO no limits disconnect? That way you retain the Rubi swaybar and the ability to disconnect faster than removing end links. Was there actually something wrong with the sway bar, or was it just not connecting properly?
    BOHICA / 2016 Mojave Sand JKU
    BOHICA Build Thread
    CRYSTAL Build Thread
  5. #15
    Fresh Catch
    Join Date
    Sep 2016
    Location
    Michigan
    Posts
    5
    haha no prob, I did take it apart and cleaned/degreased all of the gears and the housing, which gave me a great look at everything. It all looked OK from what I could tell...none of the teeth seemed mashed or were missing on the gears and I was able to get everything to work/engage manually before putting it all back together.
  6. #16
    Fresh Catch
    Join Date
    Sep 2016
    Location
    Michigan
    Posts
    5
    Quote Originally Posted by AllAmericanInfidel View Post
    I almost pulled the trigger on the EVO no limits disconnect until I discovered the inherent inch of play in the system. I assumed that the EVO unit would not have corrected that play.. Maybe it would have though? Something could have been damaged on the stock rubi disconnect as well, being the 3rd owner I cant be 100% sure what this thing was put through before I got it.
  7. #17
    Nothing but a Thing
    Join Date
    Oct 2015
    Location
    dontcare
    Posts
    1,590
    That post makes my eyes hurt. Your first mod should be to fix the return button on your keyboard and research the definition of paragraph.
  8. #18
    Knows a Thing or Two CastleRockJeep's Avatar
    Join Date
    Dec 2014
    Location
    Castle Rock, Colorado
    Posts
    505
    Quote Originally Posted by zimm View Post
    Paragraph? I couldn't read it. Thank you for those that summed it up for the rest of us!
  9. #19
    Knows a Thing or Two ScoobyCarolanNC's Avatar
    Join Date
    Mar 2015
    Location
    Raleigh, NC
    Posts
    932
    Glad you figured it out & welcome aboard!
    Sent from my duck blind.
  10. #20
    Addict jeeeep's Avatar
    Join Date
    Oct 2011
    Location
    Tx
    Posts
    5,439
    the rubicon sway bar end links need to be at the same length so it will lock up, it they're not the same length then the sway bar may not lock up properly and you'll get sway.
    when disengaged each side swings separate from the other.
    but good you figured it out
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
