Close
Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. #21
    Knows a Thing or Two RockinAZJK's Avatar
    May 2016
    Flagstaff, AZ
    587
    Quote Originally Posted by JKbrick View Post
    Is this not an issue before '12?
    Somebody correct me if I'm wrong, but I don't believe 07-11 JK's have the teflon insert to cause this problem.
    Build Thread - "Jenny"
    http://wayalife.com/showthread.php?4...=build%20jenny
  2. #22
    Addict hinrichs's Avatar
    Nov 2012
    Wyomissing, PA
    5,198
    First impression, damn this hose is big
  3. #23
    Meme King WJCO's Avatar
    Sep 2015
    Colorado
    17,293
    Quote Originally Posted by hinrichs View Post
    4fe80b15a76b8.jpeg......
  4. #24
    Knows a Thing or Two tgoss's Avatar
    Jan 2016
    San Diego
    690
    Haha, it's a joy to install too.
    Did you get the -8 return line and additional cooler as well?
  5. #25
    Nov 2012
    Wyomissing, PA
    5,198
    Quote Originally Posted by tgoss View Post
    Do you have this setup?
    Yeah went with the full upgrade.
  6. #26
    Jan 2016
    San Diego
    690
    Yes sir did about 3 weeks ago.... though 2 of the weeks the jeep was getting a new transmission but it's nice.
  7. #27
    Old Timer Ddays's Avatar
    Aug 2015
    Darlington, Pa
    4,885
    What cooler did you go with?
  8. #28
    Nov 2012
    Wyomissing, PA
    5,198
    Do you have any pics of how you routed the hoses?
    Quote Originally Posted by Ddays View Post
    I went with the inline alum cooler since my jeep already has a trans cooler from factory.
  9. #29
    Jan 2016
    San Diego
    690
    Didn't take any but I'll snap some when I'm home this evening for you.
  10. #30
    Jan 2016
    San Diego
    690
    PSC -8 AN Steering Pressure Hose
    Here you go bro. High pressure line I routed from the pump on top of the round cross member in between the lower radiator hose and the fan. Secured it with some clamps screwed into the top of it to reduce movement. Then routed kinda under/behind the coolant reservoir and around to the top of the box
    The low pressure line goes from the box routed to the front side of the radiator support where I mounted the cooler to the underside and then around the passenger side of the support up to the PSC reservoir.
    Hope that helps... I know there's a lot of shit going on under there.
