Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 86
Thread: 3.6L Oil Filter/Cooler Adaptor Housing Replacement
  1. #51
    Fresh Catch
    Jan 2019
    CO
    36
    Quote Originally Posted by shadowpaige64507 View Post
    I just did mine yesterday. Wasn’t all that hard. Just took about 3-4 hours.
    How in the world are you guys doing this in 3-6 hours? Its taking me longer than that to get these stupid wiring harness connectors loose! Everyone is different and in an impossible location to get leverage on. Already broke on tab! @#%#$%$%#$^$%^
    Is there some freaking magical chart showing me all the #$^$^$ different mopar connectors and the trick to get the locking tab to release?
  2. #52
    Nothing but a Thing Snboarder113's Avatar
    Oct 2015
    michigan
    2,323
    Quote Originally Posted by Alan McDermott View Post
    Push in first. Then wiggle back with clip released. You learn after you break a few.
  3. #53
    Fresh Catch
    Jan 2019
    CO
    36
    Quote Originally Posted by Snboarder113 View Post
    Thanks!
    That did help. I only have the 2 wiring plugs on the passenger side under the bracket and large harness left. I just can't get my hand under there to pull the plugs. I noticed on another video where he removed the fuel rails. Did you or anyone else have to do that?
    Alan
  4. #54
    Hooked rmilobrown's Avatar
    Feb 2017
    Az
    244
    The fuel rails stay attached to the lower intake and come out as a unit. Refer to the write up and pics at the beginning of this thread often. Take your time, don't take shortcuts, just follow the write up and you'll do great!
    HAPPYTRAILS
  5. #55
    Been Around the Block shadowpaige64507's Avatar
    Feb 2015
    United States
    483
    Yes, the electrical connectors are the biggest pain of the job. I found it very odd that my driver side and passenger side injector connectors were different clips/connectors. I should of took a picture, it was very strange.
    Some people on youtube were taking the fuel rail off the air intake. Per the Mopar manual you just disconnect the electrical connections and leave the rail on the intake.
  6. #56
    Fresh Catch
    Mar 2019
    colorado
    1
    excellent post!
    thanks for your post! not sure i wanted to tackle the job until i found it! good details and photos!
  7. #57
    Fresh Catch
    Nov 2018
    China
    37
    Thanks for this write up just did mine tonight only took 5 hours.
  8. #58
    Fresh Catch
    Apr 2019
    VA
    1
    This is the most helpful DIY I've seen in a long time- thanks so much! I'm unfortunately looking to tackle this on my 13 JKUR with 52k next week. Has anybody considered an oil pressure switch relocation instead of reinstalling it under the manifold? Say a 6" section of line to the firewall? Its pretty common in the miata world, but haven't heard any mention with the 3.6. Miatacage even sells a kit for $45. Am I a fool to do the relocation? Happy Jeepin!
  9. #59
    Fresh Catch
    May 2019
    South Florida
    1
    later year oil filter housing
    Really thorough writeup. Thank you. I have a 2013 JK. The sensor is bad and the relief valve is broken. It is possible/recommended to use a 2014 filter housing in a 2013? I've read the 2014 is an improved design. The filters are different which will cause confusion for eternity, but that is a hassle I'll live with if the part is better.
  10. #60
    Caught the Bug NightFox915's Avatar
    Aug 2015
    El Paso TX
    76
    I had to replace mine the seals underneath was completely gone leaking oil bad I couldn’t find it until I I threw a flashlight to the oil reservoir housing and saw a puddle of oil sitting there SOB lol I had to buy the Intake Gaskets the new reservoir housing new mopar filter new oil not to mentioned it messed up two valve rockers (driver side) this took me 3 days to finish but worth it agency wanted 5k 2 month wait hell no lol
