Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 75
Thread: 3.6L Oil Filter/Cooler Adaptor Housing Replacement
  1. #61
    Caught the Bug AgBass01's Avatar
    Sep 2019
    Round Rock, TX
    88
    Will be doing this soon, mine is leaking coolant. Going to replace thermostat and flush coolant system while I'm at it.
    Sent from my SM-G950U using Tapatalk
  2. #62
    Sep 2019
    Round Rock, TX
    88
    Parts ordered this morning, will be doing this Friday. Picked up oil cooler, intake gaskets, thermostat, coolant system flush/cleaner and coolant. Friday looks to be a long day.
  3. #63
    Sep 2019
    Round Rock, TX
    88
    Got it done Friday. Thanks for the great write up.
  4. #64
    Fresh Catch
    Oct 2019
    Southington, CT
    1
    New to this forum. Excellent write up, thanks for the detail.
  5. #65
    Fresh Catch
    Mar 2016
    GA
    1
    Cleaning upper and lower intake
    Great write up! I am in the middle of this job on my 2014 JK and it is going smooth because of the write up.
    What did you use to clean the upper and lower intakes?
  6. #66
    Sep 2019
    Round Rock, TX
    88
    I just used a little brake cleaner on a rag to wipe them off.
  7. #67
    Fresh Catch
    Sep 2019
    LA
    2
    Still lealing
    I've worked on this leak 3 times. Replaced cooler with amazon one. Pinched oring, replaced all seals on the new one, replaced oring on feed tube with thicker one. Started leaking after a week .
    I wonder if the housing itself is bad.
    Can a 2019 or -18 fit? Way big price difference from 2015.
  8. #68
    Caught the Bug III%er's Avatar
    Nov 2014
    Orange County, CA
    56
    vacuum leak
    I know this is an old thread, but has anybody experienced a vacuum leak and the break pedal going to the floor? Please help.
  9. #69
    Knows a Thing or Two A.J.'s Avatar
    Jun 2015
    Grants Pass Or.
    926
    Are you losing brake fluid? When did the problem start? Vacuum leak and brake pedal going to floor don't usually go together unless the master cylinder is leaking into the booster maybe.
  10. #70
    Nothing but a Thing NecessaryEvil's Avatar
    Aug 2015
    Illinois
    1,095
    Quote Originally Posted by III%er View Post
    Not sure if the oil cooler replacement thread is what you wanted. Is this a problem you had after the replacement?
