Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Painless or Switch-Pros control panel system
  1. #1
    Been Around the Block FuriousDz's Avatar
    Join Date
    Oct 2012
    Location
    New Jersey
    Posts
    452
    Hey all,
    Looking to go with 1 of these, does anyone have any experience with either or know of any advantage 1 has over the other? They are both around the same price.
    Painless - P/N 57000
    Switch-pros - SP-8100
    - Both can run 8 accessories
    - Painless is (8) 30 amp fuses and (8) 30 amp relays
    - Switch-pros is 8 Outputs, 7 rated @ 18A, 1 rated @ 30A
    I dont know much about electrical but looking at this it looks like the painless has a little bit of an advantage as far as all 8 being rated at 30A vs 7@18A and 1@30A on the switch-pro?
    There may be others down the line but as of now what I plan on running off of these will be;
    50" light bar which draws around 20A
    2-4 A pillar lights but they only draw about 1 A each
    front and rear air lockers eventually
    rock lights
    winch?
    Thanks!
  2. #2
    Old Timer TrainWreck618's Avatar
    Join Date
    Oct 2015
    Location
    East of St. Louis
    Posts
    2,965
    Just a suggestion, but I would wire your winch direct to your battery and not to a controller. Also, I have had the Switch-Pro's for a while now and it's been great.
  3. #3
    Join Date
    Oct 2012
    Location
    New Jersey
    Posts
    452
    Quote Originally Posted by TrainWreck618 View Post
    Yeah, on switch-pros site they suggest the same thats why I put the ? after it.
    thanks!
  4. #4
    Hooked vjusmc's Avatar
    Join Date
    Jan 2015
    Location
    Alhambra, CA
    Posts
    193
    I have been using switch Pros for two years and highly recommend them. Very straight forward install, clean small package, easy to wire and works well. I did wire my winch directly to my positive terminal on my battery.
    Good luck
  5. #5
    Join Date
    Oct 2012
    Location
    New Jersey
    Posts
    452
    Thanks for the info guys.
    Is there any opinion or downside to the 7 18A & 1 30A vs all 8 30A that's in the painless kit?
    - 2017 JKU Sport -
    - 3" Evo Enforcer w/draglink flip - KMC XD128 Machete's - 35" Cooper STT Pro's -
    - EVO 2nd Gen Rock Skins - EVO 2nd Gen Rock Sliders -
    - EVO 1/4 pounder w/Stinger -
  6. #6
    Been Around the Block gheller's Avatar
    Join Date
    Jul 2016
    Location
    New York
    Posts
    394
    I'm not familiar with Switch Pros but I do have the TrailRockers sitting here waiting for Spring to install. I can say the quality looks top notch. I like that it installs right over the battery tray which keeps the power feed very short. It also looks clean that way. The relays rated at 30A is a big plus, especially since I will be using two of the TrailRocker relays to power two direct drive compressors for air horns. Each compressor supposedly pulls about 20 amps.
  7. #7
    Join Date
    Oct 2012
    Location
    New Jersey
    Posts
    452
    Quote Originally Posted by gheller View Post
    Sweet! Yeah they both look like great products so I doubt I can go wrong with either. The only thing I was concerned about was that the switch pro only has the 1 30A switch and I know the 50" light bar will have to use that since it will draw 19 and the other 7 are rated to 18A.
    - 2017 JKU Sport -
  8. #8
    Been Around the Block Randy Tadevich's Avatar
    Join Date
    Mar 2015
    Location
    Arizona
    Posts
    296
    I have the trail rocker and really like it. Install is easy. The only negative I would say is that its slightly in the way of the battery. So its a little hassle to change the battery. I still have the stock battery tray setup. But its very professional looking.
    Sent from my LGLS740 using WAYALIFE mobile app
  9. #9
    Nothing but a Thing
    Join Date
    Oct 2015
    Location
    dontcare
    Posts
    1,590
    I have the Painless. I like it.
    http://wayalife.com/showthread.php?4...l=1#post843934
    I don't like electronics or circuit boards in something that can be handled by heavy duty 30 amp relays and fuses. Less to go wrong and if something does go wrong, you can plug in an auto parts store relay.
  10. #10
    Join Date
    Oct 2012
    Location
    New Jersey
    Posts
    452
    Quote Originally Posted by zimm View Post
    Cool! Thanks for the info
    - 2017 JKU Sport -
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
