Ewisch
Well I felt pretty good about getting the bumper on the Jeep today, but after I pulled out of the garage I heard a crack when I turned my steering wheel to the right about one full turn.
After hearing the noise I got out to take a look and found that the clamp (can't remember the exact name for this piece) that connects the drag link to the tie rod end that goes into the pittman arm, is trying to kill the plug on my sway bar disco. The piece that cracked was the black cover that goes over the plug, I pulled that off, unplugged the plug and tucked it up out of the way to drive it home.
Here is a closeup with the wheel turned at about 3/4's of a turn to the right
Here is what the motor looks like after the relocation
Not sure if I did something wrong with the relocation, do I need to drill further into the new mounting point? Did I tighten the bolt too much or not enough? Do I need to loosen the clamp on the drag link and rotate it so the bolts are facing down instead of facing forward? Or am I missing something else, any advice would be greatly appreciated.
