Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Stock Jk Tie Rod Stud Stripped?
  1. #1
    Fresh Catch SkylerMitchell's Avatar
    Join Date
    Feb 2017
    Location
    Tri Cities, Washington
    Posts
    43
    I bought my first jeep back in july. Its a '09 2D JK in deep water blue pearl. It came with the essentials for a first time jeeper (bumpers, winch, lightbar, 2" lift and 33s). Couldn't have asked for anything better considering I paid nearly retail value. Well I pretty much wheeled it until the stock steering components started wearing out and I started experiencing the death wobble. It got to the point when i couldn't get over 35 without shaking out. Ive done inspections and found the track bar was my biggest issue. I replaced it with the RK Bomb Proof. Fixed the main wobble issue to where it was drivable again. Next on the list was my drag link. Bought the synergy drag link and upon install I loosened the tie rod nut on the passenger side for a little extra space to slip it into the steering knuckle. Once the DL was in i tried tightening the tie rod back up and noticed the stud was spinning with the bolt. The stud fits a 7mm hex head so i hit it with some PB Blaster and let it sit for a night. Next day i tried getting the bolt to go back down the stud and the stud stripped. Now I don't know What do do. Do I cut the stud and get a new tie rod end?
  2. #2
    Addict JKbrick's Avatar
    Join Date
    Feb 2013
    Location
    Leo, Indiana
    Posts
    7,918
    What stripped, the threads or the 7mm hex hole?
  3. #3
    Join Date
    Feb 2017
    Location
    Posts
    43
    Quote Originally Posted by JKbrick View Post
    The 7 mm hex hole. The bolt loosened with ease, but very difficult to tighten even after the PB.
  4. #4
    Join Date
    Feb 2013
    Location
    Leo, Indiana
    Posts
    7,918
    Quote Originally Posted by SkylerMitchell View Post
    Try to place a bottle jack under the tie rod end and push up on it then maybe the nut will tighten, not sure other than that
  5. #5
    Join Date
    Feb 2017
    Location
    Posts
    43
    I'll try that and see what happens, thank you for the input.
  6. #6
    Addict jeeeep's Avatar
    Join Date
    Oct 2011
    Location
    Tx
    Posts
    5,619
    you can try to tap in a slightly larger allen wrench in it to hold it in place
  7. #7
    Join Date
    Feb 2017
    Location
    Posts
    43
    Quote Originally Posted by jeeeep View Post
    I took bricks suggestion with the bottle jack underneath and used a larger allen as well. Using the combination of the two I still couldn't get the stud to hold. I'm all out off options now, starting to think I might have screwed myself
  8. #8
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    28,858
    Can you use a Dremel with a cutoff wheel and make a slit in it and then use a screwdriver?
    Jeep JT GLADIATOR FORUM: www.JT-Gladiator.com
  9. #9
    Join Date
    Feb 2017
    Location
    Posts
    43
    Quote Originally Posted by WJCO View Post
    That's a really good idea, but the top of the bolt is above the tip of the stud I don't think i could make that work. This is how it looks IMG_4719.jpg
  10. #10
    Old Timer Andy5160's Avatar
    Join Date
    May 2016
    Location
    New York
    Posts
    4,125
    If you hand tight the nut is there any space left so you can just hold the top with channel locks by the thread? It may not be the best option but if there is nothing else left i would try it.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
