Page 60 of 91 FirstFirst ... 1050585960616270 ... LastLast
Results 591 to 600 of 902
Thread: What problems does your Jeep have this week?
  1. #591
    Nothing but a Thing Snboarder113's Avatar
    Oct 2015
    michigan
    1,613
    Death wobble only turning left. That’s a new one.
  2. #592
    Fresh Catch littlebeas's Avatar
    Oct 2018
    Indiana
    30
    Weird brake issues. Front passenger caliper froze up, so I replaced that. After the road test I took a temp gun to the rotors and the driver rear was significantly cooler than the rest, maybe that caliper is bad too?
  3. #593
    Fresh Catch medic2283's Avatar
    Apr 2019
    PA, Philly
    37
    Quote Originally Posted by 19YJ94 View Post
    Yeah both have been fixed but I haven't noticed anything out of place or deformation on the dash. So no problems other than the latter (airbag light).
    Any codes thrown for a bad clock spring by chance?
  4. #594
    Fresh Catch
    Mar 2019
    MI
    4
    I just did ball joints on my 17 JKU. The factory ones were shot after 40,000 miles. The previous owner must have aimed for every pothole. It was quite an interesting experience. The ABS sensor was rusted into the driver side hub and one of the hub bolts took out all the threads. Everything went back together smooth after that and the Jeep drives normal.
    Up next is fixing the wonderful radiator leak that so many talk about.
    I also replaced some of the factory stickers on the Jeep.
  5. #595
    Been Around the Block kep01's Avatar
    Nov 2015
    tennessee
    264
    I just installed a ultimate Dana 44 with the e-locker in the front and I have diff fluid coming out of the vent tube. Possible overfill???
  6. #596
    Oct 2012
    SoCal
    31,614
    Quote Originally Posted by kep01 View Post
    Yes.
    2012 Dozer JK
    -Dynatrac PR44/Rubicon Rear
    -Nitto 37” Trail Grapplers
    -Rock Krawler 2.5” Lift
    -ATX Slabs
    -Warn VR8
    -EVO Armor/Bumpers
    2012 Billet Silver JKUR
    -EVO DTD front and rear
    -Dynatrac PR60/PR80
    -EVO High Clearance Long Arm
    -Nitto 40” Trail grapplers
    -KMC Machetes
    -Warn CTI 9.5
    -EVO Armor/Bumpers
    1975 DJ5
  7. #597
    Nov 2015
    tennessee
    264
    Yes.
    Thanks overlander, appreciate the feedback. Just got a little worried after spending the time and money on it.
  8. #598
    Knows a Thing or Two A.J.'s Avatar
    Jun 2015
    Grants Pass Or.
    939
    Most likely yes. I can't recall how the diff cove looks on those. How high is the fill plug? It seems like I remember them having a smaller check hole below the fill plug?
  9. #599
    Nov 2015
    tennessee
    264
    Quote Originally Posted by A.J. View Post
    I’ll take a look for that. We are headed out today to do some light wheeling and see how the new axle works out.
  10. #600
    Been Around the Block 98XJ06LJ's Avatar
    Jul 2017
    US
    381
    The PSC PK1852 high volume pump on my XJ decided to evacuate the fluid while driving down the highway yesterday. The shaft seal failed, causing all the fluid to spray against the back of the drive pulley. Needless to say that the entire engine compartment and the underside of the Jeep is now covered with oil.
    Good thing is that I smelled oil burning and pulled over before it completely drained the system. Bad thing is that you can't just walk in to the local auto parts and grab some SWEPCO 715 power steering fluid.
    PSC is sending a new pump and there was no major problems caused by the failure but if this had happened out on a run there is no way I would have been able to get back to pavement. This was no slow drip. Anyone running hydro assist might want to make sure you have extra fluid and a way to bypass the pump. That seal went and it emptied the reservoir quick. Not to mention the fire risk of covering a hot engine and header with oil.
    Anyway, just a heads up.
    Sent from my Moto Z (2) using WAYALIFE mobile app
