Results 1 to 4 of 4
Thread: Dogde Dana 80
  1. #1
    Been Around the Block klungly's Avatar
    Join Date
    Jun 2016
    Location
    poulsbo WA
    Posts
    269
    Dogde Dana 80
    Does anyone know if a Dodge rear Dana 80 is worth it?
  2. #2
    Been Around the Block Basscat's Avatar
    Join Date
    Sep 2016
    Location
    Durango, CO
    Posts
    346
    Quote Originally Posted by klungly View Post
    As a rear assembly for a JK? Awfully big diff. Clearance might be a big issue. Strength is there but weight and clearance are not.
  3. #3
    Nothing but a Thing Grubbicon's Avatar
    Join Date
    Apr 2014
    Location
    Sandy Springs, GA
    Posts
    1,928
    Dogde Dana 80
    Stay away from any dodge axles. You could use their old kingpin fronts but they are lowpinion and passenger side drop and wont go in your Jeep. The aftermarket support for dodge axles are terrible and the newer fronts are center disconnect which is just junk. That being said do yourself and put a newer disk brake 14bolt in the rear.
  4. #4
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    42,986
    If you're running big enough tires and motor, the size and weight might not be too big of an issue but I'd have to agree you might not want to go down this path if only because there isn't much support for it.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
