Close
Page 12 of 12 FirstFirst ... 2101112
Results 111 to 118 of 118
  1. #111
    Hooked Tanktitan's Avatar
    Jun 2016
    Tennessee
    108
    Quote Originally Posted by GraniteCrystal View Post
    You sure it charges your iPhone? I thought that port was data transfer only.
    My plan is to run a cord behind the dash to the cigarette lighter and then plug that hole.
    As to the iPhone, well it shows the lighting bolt as if it is charging. Same for the USB in my armrest.
    You may have the right solution, connecting to the cigarette lighter behind the dash. I looked at this when I had the dash off.
    Here is my problem - is there a polarity issue? I would think there is. I want to split the USB charger and power both the iPad and a Garmin VIRB camera. I don't want to fry them.
  2. #112
    Addict GraniteCrystal's Avatar
    Aug 2015
    Denver, CO
    5,180
    Quote Originally Posted by Tanktitan View Post
    Does the VIRB camera charge off the USB? If so, I'd power that there and iPad off cig lighter. I wouldn't split and try to charge both. I think it'd either be really slow charging or you'll blow a fuse.
  3. #113
    Been Around the Block elgordomucho's Avatar
    Mar 2016
    Arizona
    406
    Probably sound like an idiot but here I go. What version iPhone? The old ones would charge off any outlet/cable. Newer ones (including iPad 2, need lightning approved cables and outlets
  4. #114
    Jun 2016
    Tennessee
    108
    The VIRB will charge off a Mac USB which I believe puts out 5 volts at 0.5A. So it may work but will do more checking first.
    However I have now found that the iPad requires 5.1 volts and 2.1A. The iPhone needs 5 volts at 1.0A.
    Clearly the 430N is not putting out 2.1 amps. I found one source saying it is 0.5A.
    Walmart sells a 4 way cigarette adaptor by BESTEK that has all these ports. Picture below:
  5. #115
    Nothing but a Thing Clifford33's Avatar
    Nov 2014
    California
    1,674
    now i just need an i pad
  6. #116
    Fresh Catch coolarmybrat's Avatar
    Jan 2017
    US
    25
    Quote Originally Posted by 2011jk View Post
    Yes they are a few months away at least what they told me in a email.
    K. Thank you for the info.
    Sent from my SM-N900T using WAYALIFE mobile app
  7. #117
    Fresh Catch Stinson's Avatar
    Aug 2013
    Columbus, OH
    4
    Fail....
    Guess the coupon expired before midnight...
  8. #118
    Aug 2015
    Denver, CO
    5,180
    Quote Originally Posted by Stinson View Post
    Timezone most likely. Give them a call and ask them.
