Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Does it matter if brake fluid is synthetic
  1. #11
    Knows a Thing or Two cavfighter's Avatar
    Join Date
    May 2016
    Location
    Carson City, NV
    Posts
    993
    Ive seen some nasty brake systems after someone mixed synth and regular. As mentioned earlier, all seals were extremely swollen and the vehicles required a complete brake system overhaul. Ive never tried flushing out conventional and running synthetic to see if same results. Im not sure if the rubber seal compounds are different or if its just a chemical reaction. Good luck. It wast on Jeeps Ive seen this but Id imagine end result would be the same.
    sent from my Illudium Q-36 Explosive Space Modulator
  2. #12
    Old Timer JKbrick's Avatar
    Join Date
    Feb 2013
    Location
    Leo, Indiana
    Posts
    3,687
    Quote Originally Posted by cozdude View Post
    This is true. You can mix any dot 3 brand together and you can put some dot 4 with dot 3. 5.1 and 5 should ONLY be added if it's an emergency but will need to be flushed out with a full brake system flush afterwords.
    What does the number after dot mean?
  3. #13
    Knows a Thing or Two madstiles's Avatar
    Join Date
    Apr 2016
    Location
    Panama city , Florida
    Posts
    792
    Quote Originally Posted by JKbrick View Post
    Part of it is the boiling point is higher the higher the number. I'm sure there's more to it than that but that's all I remember lol you can run a higher number than factory but not lower
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
