Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
Thread: Ball joints
  1. #11
    Old Timer VeruGE*144's Avatar
    Join Date
    Feb 2017
    Location
    Illinois, Chicago
    Posts
    2,654
    Quote Originally Posted by silverbullet88 View Post
    I wouldn't just run out and buy some if you don't need them. If yours have no play then there not going to magically explode and fall out. I have a pair of HD ball joints sitting in my garage. I check for play periodically and keep driving along.
    I also run 35's.
    Now that is smart ! I have a set of ProSteers siting in my garage also. I do need to change them out because I have a little play on diver side, also annoying squeak that comes and goes. Hopefully next sat I will get to it.
    For the OP
    I am at 47k miles on my stock ball joints, almost 20k of those are with 37's. They lasted quite a while. Just like silverbullet mentioned I would keep a set on hand and replace when time comes.
    MY BUILT/REBUILD: http://wayalife.com/showthread.php?4...931#post859931
  2. #12
    Caught the Bug RollingThunder89's Avatar
    Join Date
    Mar 2017
    Location
    Anaheim, Ca
    Posts
    86
    I also run 35's.
    I get a shake, vibration, shimmy, or what ever you want to call it when I am driving on the highway. This only happens between the speeds of 55-60 mph, anything after and before those dreaded speeds the ride is smoother than can be. I would hate to be going 55 mph and develop DW. 80% of the time I'm on the 91, 57, and/or 5 freeway since I do live in SoCal. My Jeep is my DD and I want to feel safe and comfortable when I drive on the pavement or off road. Because as you already know you can't put a price on piece of mind since you have spare ball joints just laying around collecting dust.
    With that said thank you for your input.
    Sent from my E6790TM using WAYALIFE mobile app
  3. #13
    Hooked silverbullet88's Avatar
    Join Date
    Sep 2016
    Location
    California
    Posts
    113
    Quote Originally Posted by RollingThunder89 View Post
    That shimmy could be a lot of things! Sounds like a tire weight to me.
    Use the ol floor jack and pry bar/ shovel method to check out your BJ's. And wheel bearings while your at it.
  4. #14
    Old Timer JKbrick's Avatar
    Join Date
    Feb 2013
    Location
    Leo, Indiana
    Posts
    4,214
    The play must be very hard to see by just looking. I fought dw all summer last year and tried that method. With only 13,500 miles all on stock tires I kept telling myself it wasn't ball joints. I finally gave up and took it apart and the lower ball joints were just hanging there all floppy and loose. Pro steers seemed to have fixed it
  5. #15
    Join Date
    Mar 2017
    Location
    Anaheim, Ca
    Posts
    86
    I got 2 different​ tire shops to align and balance my tires/wheels, Allen tires and discount tires. So I'm assuming it's safe say that the tires and wheels are properly balanced.
    I got a question for you my fellow community member which HD ball joints do you have waiting to be installed?
  6. #16
    Join Date
    Mar 2017
    Location
    Anaheim, Ca
    Posts
    86
    Quote Originally Posted by JKbrick View Post
    You and I although I've only been fighting DW for about 6 months. Thanks for your input 😀
  7. #17
    Join Date
    Feb 2017
    Location
    Illinois, Chicago
    Posts
    2,654
    Ball joints
    I had shimmy caused buy improper tire balance. I always go to sucking tire for rotation and balancing. It really depends who does it, one I had college student balance my tires and he didn't really do a good job (caused shimmy between 50-60mph) Went back to rebalance by a veteran employee and just that alone almost took care of the shimmy.
    As far as you ball joints I would make sure that that is a cause of your problem (shimmy)
    Like others mention shimmy or DW can be caused by many different things.
    Don't fix it if it ain't broke.... but keep a set in hand when it's time do replace.
    Edit:
    Discount tires not sucking tires lol, fucking autocorrect
  8. #18
    Join Date
    Feb 2013
    Location
    Leo, Indiana
    Posts
    4,214
    Your welcome, I got lucky and jumped on a used set of pro steers on here maybe 3 years ago but figured I'd need them eventually and it saved me $
  9. #19
    Join Date
    Sep 2016
    Location
    California
    Posts
    113
    I have the Teraflex HD balljoints( non knurled)I have 53k miles on my stockers. No play and no weird vibes etc.
    I'll give the TF's a try eventually. Good reviews for them. It was between those and synergy's which had a lot of negative reviews. If I could go back I would probably just buy prosteers but I didn't know much back when I bought them.
  10. #20
    Join Date
    Feb 2017
    Location
    Illinois, Chicago
    Posts
    2,654
    Did you install those yet. I read reviews saying that you will have clearance issues with your axle shafts if you have a Rubicon because the shafts are beefier than d30. They want you to grind the shafts down at the u joint to allow clearance for the lower ball joint.
    I also looked at those and that was a reason I didn't get them because I didn't want to deal with that.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
