Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Ball joints
  1. #21
    Old Timer VeruGE*144's Avatar
    Join Date
    Feb 2017
    Location
    Illinois, Chicago
    Posts
    2,655
    Quote Originally Posted by silverbullet88 View Post
    I have the Teraflex HD balljoints( non knurled)I have 53k miles on my stockers. No play and no weird vibes etc.
    I'll give the TF's a try eventually. Good reviews for them. It was between those and synergy's which had a lot of negative reviews. If I could go back I would probably just buy prosteers but I didn't know much back when I bought them.
    This is from their instruction sheet:
    Some 2012 and ALL newer Jeep Wranglers come factory with larger front axle shafts (Dana 30 & 44) than previous years, and will require grinding on the stub shaft forging parting line for clear- ance. Check axle shaft clearance by rotating the unit bearing pointed straight, and turned both directions. Grind where needed to provide adequate clearance.
    MY BUILT/REBUILD: http://wayalife.com/showthread.php?4...931#post859931
  2. #22
    Join Date
    Feb 2017
    Location
    Illinois, Chicago
    Posts
    2,655
    And here's a pic of what happens if you have clearance issue, that is just crazy stupid if you ask me
  3. #23
    Caught the Bug RollingThunder89's Avatar
    Join Date
    Mar 2017
    Location
    Anaheim, Ca
    Posts
    86
    Yeah I was gonna go with the TF cuz if the life time warranty but finding out they are not American I opted out.
    Thanks for your input 😇
    Sent from my E6790TM using WAYALIFE mobile app
  4. #24
    Join Date
    Mar 2017
    Location
    Anaheim, Ca
    Posts
    86
    Quote Originally Posted by VeruGE*144 View Post
    Ow
  5. #25
    Hooked silverbullet88's Avatar
    Join Date
    Sep 2016
    Location
    California
    Posts
    113
    Yeah I have a 2010 so my shafts are ok. I do have a spare set out of a 12 rubicon though. I'll have to make sure they are the smaller yoke shafts.
    Like I said I would probably get Prosteers to avoid all the issues with TF. Haha too late now!
  6. #26
    Nothing but a Thing Andy5160's Avatar
    Join Date
    May 2016
    Location
    New York
    Posts
    2,415
    Quote Originally Posted by WJCO View Post
    I honestly don't know anything about them, but I found this thread which doesn't shed much info on them:
    http://wayalife.com/showthread.php?3...ng-ball-joints
    Thank you for the info.
  7. #27
    Fresh Catch
    Join Date
    Mar 2017
    Location
    V
    Posts
    35
    I replaced mine with the synergy ones when I welded on the c gussets the passenger ones were fine at 50 k miles but the lower driver was starting to go. I'm at 76 k with the synergy ball joint so 25k miles on them. They have held up good and I got toyo mt 37x13.5r17 wheels with raceline beadlocks. That 135 lbs per wheel. I don't use a steering stabilizer and have no death wobble or vibration. Dynatrac ones are cool but I can replace the senergy ones a couple times before they would pay off. I'm guessing the wheel hub bearings will give out before the ball joints do
    Jku rubicon 5.13 yukon gears 37x13.5r17 toyo mt on raceline beadlocks 10k X2O winch poison spyder bfh bumper and rock sliders and crusher corners 2.5 aev lift with rolled and cut fender wells diy drop gate fastback top. Coming soon : poison spyder bfh rear crossmember with hitch
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
