bruggymonster
To start off I have a 2013 JKUR with 37s. So about a week ago I decided switch the gear ratio to 4:10 on the programmer so it would be correct for the rubicon axle ratio and it felt like it was not shifting at the right points. After I did this, I felt a loss of power and/ or a loss of maybe 1st, 2nd, or 3rd gear. After driving about 5 miles I got a check engine light so I flashed the code and got P0733 and know that it is an error in the 3rd gear. I quickly pulled over and changed the gear ratio back to 3:73 and cleared the DTCs and it ran fine. After a week of spring break and no driving, I came home and drove about 1 mile and the check engine light came in with the same code and is now doing the same thing. What do I diagnose this as/ has anyone else had this problem before? Also am I good to drive it for now or should I park it until it's fixed?
Any and all comments are welcomed, I'm freaking out because the engine and tranny only have 54,000 miles on them.
