Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 62
Thread: VIDEO : SCRUB RADIUS - What it's All About & The Dynatrac PRO 1550 Knuckle
  1. #41
    Knows a Thing or Two Journeyman's Avatar
    Join Date
    Nov 2015
    Location
    Julian, Ca
    Posts
    866
    So does castor effect the scrub radius? Curious cause when we lift our jeeps we usually lose a couple degrees of negative castor for the sake of the front drive line.
  2. #42
    Old Timer JKRay's Avatar
    Join Date
    Oct 2011
    Location
    Red Bluff, Ca
    Posts
    3,036
    VIDEO : SCRUB RADIUS - A Look into the Design of the Dynatrac PRO 1550 Knuckle
    Awesome video! Thanks!
  3. #43
    Token East Coast Guy MR.Ty's Avatar
    Join Date
    Apr 2014
    Location
    South East Georgia
    Posts
    6,264
    I am now educated on Scrub Radius! Thank you Dynatrac and WAL!
    2014 JKUR "Stumps"
  4. #44
    Been Around the Block TOPLESS's Avatar
    Join Date
    Mar 2015
    Location
    Benton Harbor, Michigan
    Posts
    451
    Quote Originally Posted by MR.Ty View Post
    I second this thought!
  5. #45
    Hooked doubletapdaddy's Avatar
    Join Date
    Aug 2014
    Location
    Colorado
    Posts
    116
    Quote Originally Posted by cameleer View Post
    A Jeep JK stock wheel backspace is 6.25". With 32" tires this has the stock factory scrub radius.
    Changing to aftermarket wheels with a backspace of 4.5", the scrub radius is now off from stock.
    Adding 37" tires changes the scrub radius again, moving it closer to stock.
    I would like to know, with aftermarket wheels backspaced at 4.5". What size tires will put you back to the stock scrub radius, or the best scrub radius.
    Holy crap...
    I swear that this was on my 5th grader's math homework last week!?!?!
    (I didn't know the answer then either) Lol.
  6. #46
    Living the WAYALIFE JAGS's Avatar
    Join Date
    Aug 2012
    Location
    SoCal
    Posts
    10,239
    Love the detail Jim went into and with having the illustrations. Very cool.
    I think I may consider lifting my Jeep. Or not.
    The Evolution of ENVY
  7. #47
    Been Around the Block scrhino's Avatar
    Join Date
    Oct 2012
    Location
    Auburn, AL
    Posts
    323
    So the scrub radius is better the taller the tire. 40 is better than a 37. How does the 1550 compare to the pro 60 wheel end? Does it have a higher inclination angle? Mel said spicy chicken steers better even though he's running 3.5 bs.
    Liston
    2010 JKUR LS3 6.2 430 HP / 6L80
    Instagram: black_rhino_jk
    EVO Go Fast Suspension and Bumpers
    Warn Powerplant
    Dynatrac XD60/80 Axles
    Rockhard 4x4 Sportcage
    37x12.50x17 Trail Grapplers on Atx Chamber Pro IIs
  8. #48
    Addict Ddays's Avatar
    Join Date
    Aug 2015
    Location
    Darlington, Pa
    Posts
    5,951
    Add to my weekend-to-do list: Remove wheel spacers
    Great video. Isn't it amazing that just when you think you got this shit figured out, along comes new info that shows how off base you were?
  9. #49
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    45,421
    Quote Originally Posted by scrhino View Post
    The PRO 1550 knuckles were designed with 40" tires in mind and they would be the optimal tire size for them. Spicy Chicken does steer better even though Mel is still running 3.5" of back spacing and it is because of the PRO 1550. Measuring from the far outside edge tire to tire, Spicy Chicken's stance is 1" wider than Rubicat in spite of her 72.5" axle. We physically measured this.
  10. #50
    Been Around the Block sjd78's Avatar
    Join Date
    Sep 2014
    Location
    Bakersfield, CA
    Posts
    324
    Yes, that was my point. The steering axis inclination line will be at a different point with larger tires. If I understand it right, this will change where the scrub radius is according to tire size.
    I'm running a Dynatrac ProRock 44 with Reid racing knuckles, but the scrub radius does not change with this setup. Also have wheels backspaced at 4.5" and 37" tires. I'm thinking this may bring me close to the proper scrub radius.
    Do you have any rubbing issues at full lock with the 4.5" bs wheels?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
