Results 1 to 7 of 7
Thread: Painting advise
  1. #1
    Knows a Thing or Two Kalums's Avatar
    Join Date
    Jan 2015
    Location
    AZ
    Posts
    889
    Painting advise
    So got my Hard Rock 3rd row cage I was wondering if anyone had any good advise on how to properly paint the locking collars? I'm a little too poor to pay someone to paint or powder coat it so I was going to wipe it down with mineral spirits to remove and the dirt and grease then do light coats over VHT matte black but I was worried about getting it runny or too thick in the bolt holes on the locking collars. I've painted other things before, so I understand many light coats is the way to go. Any advise would help.
    Sent from my LG-LS997 using WAYALIFE mobile app
  2. #2
  3. #3
    Fresh Catch
    Join Date
    Aug 2016
    Location
    San Antonio
    Posts
    7
    I would not recommend using mineral spirits to wipe the metal down. It will leave an oily residue behind due slow evaporation. It would be better to use acetone as it has a much higher rate of evaporation so it will not leave a residue behind that will make your paint peel off.
  4. #4
    Nothing but a Thing SDG's Avatar
    Join Date
    Apr 2013
    Location
    San Diego
    Posts
    1,229
    Quote Originally Posted by Jroeling View Post
    Agreed. Acetone is the way to go. Dont do it in the garage unless the door is open as it is very volatile and the pilot light from the water heater could boom haha. Other than that its easy to use.
    Like eddie said, buy a tap and chase the holes once you are done.
    Sent from my SM-G900P using WAYALIFE mobile app
    '14 JKUR
  5. #5
    Addict catahoula's Avatar
    Join Date
    Nov 2011
    Location
    Colorado
    Posts
    6,753
    Wax and grease remover before and after sanding. Yes, light coats. Also the temp of the metal can affect dry times. Warm it up.
    Gots
    17-Inch Rubi Wheels
    295/70/17 Mastercraft Courser MXT's
    18/59 Springs & Rubi Shocks
    TF Leveling Kit
    1.5" Spidertrax Spacers
    Warn Rock Crawler Stubby & Engo 9000 Winch
    EVO Rear Bolt On "D" Ring Mounts
    EVO Rear Corner Rock Skins
    Rough Country Skids
    “Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do...
    Explore. Dream. Discover."
    "Take a compass, because it's always awkward when you have to eat a friend."
  6. #6
    Knows a Thing or Two jkris's Avatar
    Join Date
    May 2012
    Location
    Tampa, FL
    Posts
    579
    I have used foam earplugs to fill thread holes. Works pretty good
    I bet you measure your dick from your asshole. -piginajeep
  7. #7
    Join Date
    Jan 2015
    Location
    AZ
    Posts
    889
    Awesome thank you everyone, I've only ever used mineral spirits. I will try the acetone, and the painters tape +the earplugs sounds like a good idea to me.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
