Good entry level TJ Lift
JOHN73738
So I got a Rubicon express lift installed on my '16 JKU Rubicon, now I want to replace the crappy ProComp springs and shocks I installed on my Wife's '01 TJ Sport. Any suggestions in the 2.5 - 3" range? The ride of the PC hardware is like riding on cinder blocks.
Appreciate any input.
Thanks.
Barrett
John82601
For my son's XJ lift we went with a Zone Offroad 4.5" kit. The bit of research he did showed that Zone runs a lower spring rate than most of the other budget kits. The hydro shocks are a generic white shock but his Jeep rides great and, once it settled in, hasn't lost any of it's original lift. Zone has a 3" all-spring kit for your wife's TJ that would be worth looking into.
HogBlock
Did you happen to keep the factory coils from the jk? If you did, you can run those with a 2" spacers on the front and will gain about 3" of lift and a much better ride. We did it on my neighbors 2003 TJ and it rides much better. You can even use the shocks with a little work
