Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: Wall plug
  1. #1
    Fresh Catch lopezchris1267's Avatar
    Join Date
    Mar 2017
    Location
    US
    Posts
    37
    Wall plug
    Any one install a wall plug in their jk?
    Sent from my XT1650 using WAYALIFE mobile app
  2. #2
    Nothing but a Thing TrainWreck618's Avatar
    Join Date
    Oct 2015
    Location
    East of St. Louis
    Posts
    2,005
    Quote Originally Posted by lopezchris1267 View Post
    You mean like the one that's already built into the jk center console?
  3. #3
    Hooked chuck79's Avatar
    Join Date
    Mar 2017
    Location
    MD
    Posts
    139
    Not all of them.
  4. #4
    Join Date
    Oct 2015
    Location
    East of St. Louis
    Posts
    2,005
    Quote Originally Posted by chuck79 View Post
    Not all of them.
    That sucks.. had no clue, I use mine all the time.
  5. #5
    Been Around the Block Frydaddy's Avatar
    Join Date
    Feb 2016
    Location
    Phoenix
    Posts
    482
    For those of us without a Rubicon... Yes, it's not that hard to install an inverter. Here, I mounted mine under my DIY privacy cover in the rear. I have since upgraded to a 750Watt (1000 watt peak) inverter.
    To find the best one for your needs you need to do a little math to find the size you need, then work form there. You need the right sized wiring and the right fuse beside the battery to match your inverter. The stock cigarette outlet can only handle 10amps at 12v, barring losses, thats less than an amp at 120V.
    P=V*I, Watts = Volts X Current. My 750W inverter math goes, 750W/120V= 6.3Amps AC, but will draw 750W/12V= 63Amps DC. At full load, the engine should be running (and maybe revving) Since I ran about 20 Feet of wire, I need to use 4AWG size wire straight to the battery, and a 65Amp breaker to protect the wiring. Thats some heavy wiring for just 6 amps of AC power.
    A popular breaker type http://a.co/huP4P8c
    Wire sizing/distance chart http://www.engineeringtoolbox.com/am...uge-d_730.html
    Typical Appliance load chart https://www.georgiapower.com/in-your...y/chart.cshtml
  6. #6
    Join Date
    Mar 2017
    Location
    MD
    Posts
    139
    Quote Originally Posted by TrainWreck618 View Post
    I bet a bunch of people just went to their jeep to look for it.
  7. #7
    Old Timer Moochie's Avatar
    Join Date
    Nov 2011
    Location
    San Diego County
    Posts
    3,455
    I didn't.
  8. #8
    Addict GraniteCrystal's Avatar
    Join Date
    Aug 2015
    Location
    Denver, CO
    Posts
    6,068
    I bought a Rubi for the wall plug. Best $10k I ever spent.
  9. #9
    Nothing but a Thing NecessaryEvil's Avatar
    Join Date
    Aug 2015
    Location
    Illinois
    Posts
    1,072
    They install the plug and inverter in other models. I have one in my 13 Sahara with a plug on the center console. I don't know the power rating but have only used a lap top charger with it.
  10. #10
    Fresh Catch WW_Svi's Avatar
    Join Date
    Feb 2016
    Location
    Quad Cities
    Posts
    44
    Quote Originally Posted by Frydaddy View Post
    Keep in mind that nothing is 100% efficient and power supplies/inverters are rated for the output power. So if it's 750w but only 80% efficient then it will take more DC power to convert to AC.
    750w/120v=6.25A output
    (750w/12v)/.8=78.125A
    Just need to verify the efficiency of the power supply and adjust accordingly.
    Also cheaper power supplies use modified sine waves and some equipment needs a pure sine wave to run properly.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
