Page 1 of 7 123 ... LastLast
Results 1 to 10 of 61
Thread: CB Wiring
  1. #1
    Hooked Mikecal9985's Avatar
    Join Date
    Feb 2016
    Location
    Sarasota, FL
    Posts
    241
    CB Wiring
    I'm planning on adding a CB to my Jeep and had a question about the wiring. I'm thinking about purchasing the Cobra 75 WX ST and using this to wire it up
    The installation of this piece isn't my problem, my problem is that my 12v output is on the left hand side and not on the right hand side like it's shows in the instructions. Also, they seem to be hooking it up to the cigarette lighter.
    This is what my Jeep looks like.
    My question is, since they show it being hooked up to the cigarette lighter, would it work the same if I hook it up to the 12v output? And do you guys think it'll be long enough to reach by where it shows it coming out by the glove box? Sorry if this makes no sense but it's the best way I can explain it hahah. Thanks for the input guys!!
  2. #2
    Hooked chuck79's Avatar
    Join Date
    Mar 2017
    Location
    MD
    Posts
    139
    If it has the same plug it will be fine. One of them is probably always powered. And one powers with the accessories. If you are always powered remember to shut of your cb or you'll have a dead battery.
  3. #3
    Join Date
    Feb 2016
    Location
    Sarasota, FL
    Posts
    241
    Quote Originally Posted by chuck79 View Post
    On the right hand side it's just a hook looking thing, no power. My 12v output in the left had side, goes on and off with the ignition, the 12v output that always stays on, is in my center console.
  4. #4
    Join Date
    Feb 2016
    Location
    Sarasota, FL
    Posts
    241
    Just so everyone knows I have a 2011 2dr sport. If that makes any difference
  5. #5
    Hooked davidc128's Avatar
    Join Date
    Mar 2017
    Location
    US
    Posts
    159
    Imo it seems easier to hit the battery with an inline fuse and b done with it
    Plus itd save u bout $30
  6. #6
    Fresh Catch estesd's Avatar
    Join Date
    Jan 2017
    Location
    Maine
    Posts
    45
    I used this same connector to my lighter on my 2015 with the same cb. It powers off when the jeep is turned off.
  7. #7
    Join Date
    Mar 2017
    Location
    MD
    Posts
    139
    If you already have that harness just extend it where needed.
  8. #8
    Join Date
    Mar 2017
    Location
    MD
    Posts
    139
    Quote Originally Posted by estesd View Post
    Good idea. I've seen a few keeps dead in the morning from not turning off the cb with a battery home run.
  9. #9
    Join Date
    Jan 2017
    Location
    Maine
    Posts
    45
    I also have a lighter adapter under the dash tied into the same connector to power my gps and ran the wire between the windshied and dash. This frees up the lighter in the dash for cell phone charging.
  10. #10
    Knows a Thing or Two Dopey84's Avatar
    Join Date
    May 2015
    Location
    Idaho
    Posts
    732
    I went this route and just spliced the wires and plug in my cb only when needed... (I'm forgetful and didn't wanna chance a dead battery) works great though
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
