Close
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 61
Thread: CB Wiring
  1. #21
    Hooked Mikecal9985's Avatar
    Join Date
    Feb 2016
    Location
    Sarasota, FL
    Posts
    232
    Quote Originally Posted by chuck79 View Post
    Did you already buy the lighter harness?
    No I haven't. I haven't bought anything yet, just getting all the info I can before pulling the trigger
  2. #22
    Join Date
    Feb 2016
    Location
    Sarasota, FL
    Posts
    232
    Quote Originally Posted by BananaJeep View Post
    A fuse tap is only about $5 and all you'll need to do is run a wire from the fuse box to where you want your CB to go. IMO easier, and cheaper. And you can either pick an always hot fuse (constant 12v), or a switched fuse (switched 12v) that way when you take your key out, your CB shuts off. That's how I have mine wired, because I used to forget it and leave it on all the time.
    So with a fuse tap, the red wire would go to the fuse tap and the black I would just have to ground to one of the grounding screws under hood? Am I getting this correct? Also where might I find something that'll tell me which one of my fuses is hot or a switched one?
  3. #23
    Nothing but a Thing BananaJeep's Avatar
    Join Date
    Sep 2016
    Location
    Nebraska
    Posts
    1,010
    Quote Originally Posted by Mikecal9985 View Post
    Exactly. Red wire would be your positive, and black is ground. You could even ground the CB inside the cab somewhere that way you're only running one wire through the firewall.
    You can get a tester light at autozone or alike for about $5, or you could spend a little bit and get a multi-meter that'll work as well. But sometimes just by looking at them you can tell... for example, your wiper fuse is switched because your wipers turn off with the key.
    2006 Jeep TJ
    "The Banana Jeep"
  4. #24
    Old Timer jeeeep's Avatar
    Join Date
    Oct 2011
    Location
    Tx
    Posts
    4,352
    Thanks for the great info guys...let's just hope when I take apart the whole dash the plug I need will be there
    You don't need to take apart any of the dash just look under the dash from the passenger side at the console level.
    If the wiring is there you'll see it right away.
    If the plugs are still left in place the harnesses makes it easy to plug into it without any issues otherwise using a wire tap is just as easy all you have to do is locate an ignition hot wire.
    I would recommend going with the ignition switched hotwire so it'll turn the cb off.
    you don't want to leave the CB on and kill the battery
    Seems the CB kills the battery fast
  5. #25
    Join Date
    Feb 2016
    Location
    Sarasota, FL
    Posts
    232
    Awesome!!! Thanks for all the help guys!!!
  6. #26
    Join Date
    Feb 2016
    Location
    Sarasota, FL
    Posts
    232
    One last question...what are y'alls thoughts on wiring it to my Spod? That way I can just switch it on and off
  7. #27
    Hooked chuck79's Avatar
    Join Date
    Mar 2017
    Location
    MD
    Posts
    137
    I think it's a waste. It has a switch. No need for another one.
  8. #28
    Join Date
    Oct 2011
    Location
    Tx
    Posts
    4,352
    why switch it twice? - just turn it off using the CB switch
  9. #29
    Join Date
    Feb 2016
    Location
    Sarasota, FL
    Posts
    232
    Got it...just asking
  10. #30
    Join Date
    Feb 2016
    Location
    Sarasota, FL
    Posts
    232
    Ok I bought the CB and now looking at getting everything else I need...would you guys say a 9' of 18' coax cable for a two door? I'll be running along the roll bar all the way from the glove box, to the tailgate. I've seen plenty of guys running the 18' on a four door, but not sure about a two door. I've also learned that it's not good to loop the coaxial, so I'm not sure what I would do if it had a bit left over if I went with a 18'.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
