Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: 4" Plush Ride Expectations
  1. #1
    Hooked moteaux's Avatar
    Join Date
    Dec 2013
    Location
    Conroe
    Posts
    136
    Ok, let me just start by saying that I know ride is a personal preference and by the time I finish this post, I will likely be accused of blasphemy, WW3, WMDs and hating puppies. BTW, I love puppies.
    I recently have been going through some upgrades. I had an RC 3.5 lift on my jeep with the RC shocks. It didn't take long, but the ride quality deteriorated some, but it actually wasn't bad. In the process of gathering parts for my upgrades, I acquired some low mileage Fox 2.0 shocks and Evo 4" Plush ride coils (NIB). I quickly swapped in the shocks and noticed an immediate difference in ride quality and was highly impressed with the improvement.
    Next, I changed the coils when I did my axle swap. The 4" coils gave me nearly 2 inches height over the 3.5RC. I'm sure there will be more settling in and they will lose a bit of this but that's what I measure currently. Also, I will note that I am still running the stock rear control arms and have ordered longer, adjustable LCA/UCA to put the axle back in place. Running 37s, it's really close to the rock rails with stock arms (pic attached) and will be corrected. IMG_5010.jpg
    Here is said blasphemy. To me it doesn't ride as well as with the RC set up with the Fox upgrade. I'm hoping that some of this will be remedied by control arms getting the rear back in more correct position, but I'm not sure if I can count on that. Also, I am hoping with break-in time, they will get better. My best way to describe the current ride quality is that it's ok in terms of harshness, with a bit more jarring sensation on initial impact of things like road deviations or speed bumps at Home Depot. I have yet to find a suitable mall to really put it to the test, and unfortunately I'm out of the country for work and can't do much until I get back, except ask questions on forums and throw parts catalogs at it. I prefer the former.
    The questions will be asked so I will say that I followed the torque specs given in the write ups, but will double check when I get home to ensure none of the arms are over torqued and causing some of the harshness.
    So I guess I was expecting a much better ride over the previous setup, but currently a bit disappointed. Looking for ways to ensure that I have done due diligence in addressing installation QA and anything else plus any forum users experience on break in times and expectations, if any exist.
    Thanks and looking forward to experiences and suggestions.
    BTW, I like cats too... if they're cooked right.
  2. #2
    Guy with a Red 2-Door cozdude's Avatar
    Join Date
    Mar 2013
    Location
    West Chester, PA
    Posts
    17,503
    When you installed the lift did you wait til torque your control arms till it was on the ground? Did you also give the Jeep a good shake down to help it settle a little during that process? The control arms could be binding a little
    As for the coils, just give them a little time. They should settle a hair under the weight of your Jeep
    October 16, 2013, wednesday early evening, east of the pacific ocean, selectee for truly random and boring Parking lot photo of the moment grand platinum prize winner!
    2011 JK
    EVO Bolt-on Coilovers, EVO 1/4 pounder w/ stinger, 37" Cooper STT Pros, PR44, and some EVO stuff
    Awaiting install-
    On Order-
    Want list- Evo carrier and skins, PSC hydro assis
    jlwrangler.com
  3. #3
    Join Date
    Dec 2013
    Location
    Conroe
    Posts
    136
    Quote Originally Posted by cozdude View Post
    I guess I should say the ride height at current level doesn't bother me. Just surprised at the gain over the 3.5RC. Settling in will be anticipated a bit more then? Thinking as it settles in it may soften up.
    Good point about torquing the bolts. I would say I got them "fairly" tight then did the final check to appropriate torque once on the ground. No qualms with going back and loosening them up and then doing over again, especially the front. The rears will be replaced soon. I ordered new and I see you sold the Synergy brand Cozdude 🤣
    Thanks for the reply and pointers
  4. #4
    Join Date
    Mar 2013
    Location
    West Chester, PA
    Posts
    17,503
    Quote Originally Posted by moteaux View Post
    When you measured your ride height where did you measure? Did you measure the coil spring perch or did you use a fender?
    For the bolts I would just loosen them all on a flat surface, then you jump on the front and rear of the Jeep a couple times to help the bushings free up and it should let everything fall into place, then you can go back and torque it all to spec.
    Lol yes I sold the arms.
    2011 JK
    Awaiting install-
    On Order-
    jlwrangler.com
  5. #5
    Join Date
    Dec 2013
    Location
    Conroe
    Posts
    136
  6. #6
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    21,264
    4 inch lift on short arms, you will definitely feel the bumps and imperfections more IMO. Also, I'm assuming your already had a drag link flip with your previous lift?
  7. #7
    Join Date
    Mar 2013
    Location
    West Chester, PA
    Posts
    17,503
    Use this diagram to measure lift height instead
    JK FAQ - Answers to Questions Every Newbie has about the Jeep JK Wrangler
    http://wayalife.com/showthread.php?t=2180
    2011 JK
    Awaiting install-
    On Order-
    jlwrangler.com
  8. #8
    Knows a Thing or Two madstiles's Avatar
    Join Date
    Apr 2016
    Location
    Panama city , Florida
    Posts
    813
    Can't help but great looking rig !
  9. #9
    Join Date
    Dec 2013
    Location
    Conroe
    Posts
    136
    Quote Originally Posted by WJCO View Post
    Didn't have the flip before, but I do now with the current set up.
  10. #10
    Knows a Thing or Two tdougherty81's Avatar
    Join Date
    Jan 2015
    Location
    Willis, Tx
    Posts
    995
    When you get back into town let me know. You can take mine for a spin and compare the two since we are both on 4" plush.
    2013 JKU Rubicon Commando Green
    Hound
    Build Thread - http://wayalife.com/showthread.php?4...-Green-Rubicon
    2016 BU Renegade Trailhawk Anvil
    Mamahawk
    Build Thread -
    Sold-2008 JKU Red Rock Crystal Pearl
    RedRock
    Build Thread - http://wayalife.com/showthread.php?2...dRockJKU-Build
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
