Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Synergy tie rod end.
  1. #1
    Nothing but a Thing Mybadjk's Avatar
    Join Date
    Dec 2016
    Location
    Elko
    Posts
    1,287
    So this is my second synergy tie rod end for my draglink. I can't get the castle nut tightened enough to put a cotter pin through. Anyone else have this problem?
  2. #2
    Hooked chuck79's Avatar
    Join Date
    Mar 2017
    Location
    MD
    Posts
    139
    Take it off and drill it a bit more.
  3. #3
    Been Around the Block aermotor's Avatar
    Join Date
    Feb 2015
    Location
    Los Angeles
    Posts
    487
    You have to drill it out further, but not too much. You go too far and it's supposedly done for. I can't get the cotter pin on mine but I'm not worried about it for how tight it is, I was getting towards the higher side of .9-1" or whatever it is they say to not exceed so I left it. Was using a 7/8 bit and did quite a bit of hogging. Maybe I'll try and go some more one day.
    Idiot with a JK
  4. #4
    Join Date
    Mar 2017
    Location
    MD
    Posts
    139
    I used a 15/16 bit. It's perfect.
  5. #5
    Join Date
    Dec 2016
    Location
    Elko
    Posts
    1,287
    I haven't measured it. But the 7/8th bit has play when it's in the knuckle. I may go get a 15/16th bit. I must of drilled to big for the tre as the hole is above the castle nut. Maybe it's time to buy new knuckles.
  6. #6
    Join Date
    Mar 2017
    Location
    MD
    Posts
    139
    Pull the boot up. If you see taper on the shaft you can drill bigger.
  7. #7
    Fresh Catch DavidDial's Avatar
    Join Date
    Nov 2015
    Location
    Georgia
    Posts
    9
    I had to do some extra drilling on mine as well, just wobble your drill bit really easy and bore it out a little more. And keep doing so until you get the cotter pin installed.
    Took 6-7 tries for mine to go down far enough
    David Dial
    2011 JKU
  8. #8
    Join Date
    Dec 2016
    Location
    Elko
    Posts
    1,287
    Quote Originally Posted by chuck79 View Post
    Never though about that... thanks man.
  9. #9
    Knows a Thing or Two Journeyman's Avatar
    Join Date
    Nov 2015
    Location
    Julian, Ca
    Posts
    866
    You guys are using the tapered adaptor for this, correct?
  10. #10
    Old Timer Jackal01's Avatar
    Join Date
    Jun 2013
    Location
    Houston
    Posts
    2,794
    Quote Originally Posted by Mybadjk View Post
    I had to buy new knuckles after drilling too large. I have the same TR. Wish I would have gone with the JKS DLF since they include a step bit. I helped a friend do his and it was 100x easier than the Synergy way.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
