Close
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Nothing but a Thing desertrunner's Avatar
    Join Date
    Mar 2013
    Location
    Great Falls, MT
    Posts
    1,056
    Manual transmission fuzz
    Just got done changing the oil on my 12 manual transmission and I know that fuzz on the magnet is normal but there were a few bigger pieces that have me questioning it a little. Just wanted to get some thoughts if I should be concerned at all? Most of the fuzz was what I am used to seeing but the few pieces that stuck around trying to clean it out are bigger than I'm used to seeing and looking at my oil catch pan there seemed to be a slight bit of glitteryness
    Attached Images Attached Images
    12' 2dr Gecko Sport 6 speed
    Cooper Stt Pro 295/70/17 ATX 195 17x9, 4Dr Rubi suspension, Rubi Swaybar w/EVO manual no limits, Rubi T case, EVO 1/4lb, Warn Powerplant 9.5
    ***SOLD*** 08' JKU Rubicon 6-speed Stone White, 3.5" RK lift, 37" KM2s and lots more.
    ***CURRENT DD*** 16' Toyota Tacoma TRD Off Road 6 speed
  2. #2
    Nothing but a Thing black pearl's Avatar
    Join Date
    Dec 2016
    Location
    Sonoma
    Posts
    1,341
    Was the level low? Or gotten gear grind ? I know sometimes my foot is faster then my hand and I get a little grind and I'm always worried about chipping a gear
    Take what you can! Give nothing back!
  3. #3
    Join Date
    Mar 2013
    Location
    Great Falls, MT
    Posts
    1,056
    Quote Originally Posted by black pearl View Post
    Oil seemed to be full (hard to tell when it all comes rushing out and my 15 quart catch has more that just that in it) and the oil actually seemed really clean but i bought it used around 7k miles ago and it now has 47k on it so im guessing it was recently changed. Im sure i have been a little sloppy shifting from time to time but nothing drastically different from my 08 6 speed and i dont remember seeing pieces that big on that one. Im sure im just over reacting but i thought i would ask
  4. #4
    Knows a Thing or Two Zstairlessone's Avatar
    Join Date
    Dec 2012
    Location
    Texas
    Posts
    632
    I wouldn't be comfortable with the chunks, we used to joke about reading the part number on pieces that size. Remember, the magnet has some limitations. It only picks particles up that pass by it, it can only pick up so much before it is 'full', it doesn't pick up brass or aluminum and it can only pick up smaller particles.
  5. #5
    Knows a Thing or Two madstiles's Avatar
    Join Date
    Apr 2016
    Location
    Panama city , Florida
    Posts
    657
    The say "Can't find em grind em" yeah that's what happens lol
  6. #6
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    17,324
    That seems a little excessive but if you aren't having any abnormal symptoms, I would change the fluid and then do it again in 5k or 10k just to see if same amount of metal appears.
  7. #7
    Join Date
    Mar 2013
    Location
    Great Falls, MT
    Posts
    1,056
    Quote Originally Posted by WJCO View Post
    That was my thought too, it doesnt feel abnormal at all seems to shift fine. I figured ill give it 5k miles drain it again and see what it looks like
  8. #8
    Join Date
    Apr 2016
    Location
    Posts
    657
    Ditto if it was an automatic I'd worry but a standard not so much
  9. #9
    Caught the Bug srbell0585's Avatar
    Join Date
    Feb 2016
    Location
    United States
    Posts
    70
    Just changed mine recently. My magnet looked the same, maybe worse. But I had some bigger pieces I wasn't excited to see. Gonna do what WJCO said and drain again in 10k and see if there is more on the magnet. I too bought it used with 25k and wonder how it was driven the first 25k. Hopefully what damage is done and I won't keep getting bigger pieces.20170414_140751.jpg20170414_140729.jpg
    Sent from my SM-N910T using WAYALIFE mobile app
  10. #10
    Hooked ChopperDoc's Avatar
    Join Date
    Mar 2016
    Location
    Maryland
    Posts
    233
    When I change my fluid my magnet is always full but never had any large pieces
Posting Permissions
  • You may not post replies
  • You may not edit your posts
