Results 1 to 5 of 5
Thread: another shock question?
  1. #1
    Knows a Thing or Two Wethy's Avatar
    Join Date
    May 2014
    Location
    Ontario
    Posts
    610
    i have a Rubicon Express 2.5" lift with the monotube shocks. i was noticing at ride height today that i have about 5" of the shaft showing on the shock, and about 2" between the bumpstop and the extension that came with my lift. my question is this. assuming i cycle the suspension, and check brake lines, coil seating and any other aspects, could i get longer shocks up front or add something like a shock extension(probably new shocks) to help keep all 4 wheels on the ground? and how much shock shaft should be showing when the shock is collapsed i dont want to bottom them out.
    the rubicon express site says the shocks are only 24.14" extended and 14.80" collapsed so i figure as long as my brake lines wont be taught, and the coil wont become unseated i should be able to add a longer shock.
    also i am running an adams driveshaft up front so i wont need to worry about the OEM driveline issues
    thanks in advance.
    '14 JK Sport Anvil 6-Spd 3.73 gearing
    Installed:
    -Rubicon Express 2.5" lift with monotube shocks
    - Cobra Cb 18 WX STII
    - 285/70/17 Duratracs
    - 1.5" G2 Wheel Spacers
    - Rigid Dually Spots
    - Poison Spyder A-Pillar Mounts
    -RC 2.5" swaybar disco's
    Awaiting Install:
  2. #2
    Knows a Thing or Two JKDream's Avatar
    Join Date
    Jul 2016
    Location
    Canada
    Posts
    879
    Quote Originally Posted by Wethy View Post
    thanks in advance.
    If you're at full bump with shaft to spare - then yes you can get longer shocks.
    24" extended is pretty short, granted you only have 2.5 inches of lift.
    Have you measured your actual lift height gained?
    A general rule of thumb - is you want at least .25" of shaft showing at absolute full bump (bumpstop to metal cup not foam).
    Remember the upper stop compresses so you want to be measuring to the metal cup above.
  3. #3
    Join Date
    May 2014
    Location
    Ontario
    Posts
    610
    Quote Originally Posted by JKDream View Post
    i have 2" from the top of the extension to the the bottom of the foam cup so its more like 3- 3.5" total space(once bumpstop is compressed). and i thought they might be fairly short. but they came with the kit.
    Installed:
    Awaiting Install:
  4. #4
    Join Date
    Jul 2016
    Location
    Canada
    Posts
    879
    Your best bet is going to be getting a proper measurement of your full bump and then looking at collapsed lengths of longer shocks.
    Once you know what the exact distance is in your uptravel - you can start looking for a longer shock set up.
    Rancho's 4" inch lift lengths are probably near what you would need, and you would gain a good amount of downtravel.
    I know I've said it already but make sure you are getting a proper measurement, you don't want to have to add more bump stop than you already have if you're almost riding on them now.
    I personally run 3 inches of lift (actual height) - but quite long (28.75 ext) shocks. But I'm bumpstopped for high steer - so I chose large downtravel opposed to up travel.
    My kit originally came with 25 inches extended, but in reality I could fit much longer.
  5. #5
    Join Date
    May 2014
    Location
    Ontario
    Posts
    610
    i do plan on getting proper measurements before i go ahead and do anything. i just wondered about the theory side of things before i go to the hassle of actually removing the shocks and checking everything
    Installed:
    Awaiting Install:
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
