Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Dropped pitman arm VS reised track bar bracket
  1. #1
    Been Around the Block Guascone's Avatar
    Join Date
    Feb 2015
    Location
    Italy
    Posts
    408
    Hi, I' m confused about the use of the dropped pitman arm , the reised track bar bracket and also the drag link flip kit.
    When should I to use them and why should I choose one of them?
    Thanks!
  2. #2
    Guy with a Red 2-Door cozdude's Avatar
    Join Date
    Mar 2013
    Location
    West Chester, PA
    Posts
    17,493
    Quote Originally Posted by Guascone View Post
    Thanks!
    A raised trackbar bracket is better than a dropped pitman arm because it doesn't add extra stress to the pitman arm itself. Also when you flip the drag link it will be more in line with the trackbar when you raise it from the axle side.
    As far as when to do it, a drag link flip and raised trackbar should be done at that same time and usually when you start going 3" of lift and higher. Kits like evo sell the raised bracket and the dl flip together so your killing two birds with one stone
    October 16, 2013, wednesday early evening, east of the pacific ocean, selectee for truly random and boring Parking lot photo of the moment grand platinum prize winner!
    2011 JK
    EVO Bolt-on Coilovers, EVO 1/4 pounder w/ stinger, 37" Cooper STT Pros, PR44, and some EVO stuff
    Awaiting install-
    On Order-
    Want list- Evo carrier and skins, PSC hydro assis
    jlwrangler.com
  3. #3
    Join Date
    Feb 2015
    Location
    Italy
    Posts
    408
    Quote Originally Posted by cozdude View Post
    Thanks, I remember your suggestion!
    I know WOL position about teraflex but I have a question...I have the opportunity to buy a teraflex drag link flip kit with the steer renforcement and all the stuff a very good price (130 dollars).
    Do you think that it is a very bad kit and I will waste my money using that?
    Thanks!
  4. #4
    Join Date
    Mar 2013
    Location
    West Chester, PA
    Posts
    17,493
    Thanks!
    Honestly, I wouldn't trust it mainly because it is terrorflex. I wouldn't want such an important steering part to be made with Chinese steel and break like their carrier do.
    2011 JK
    Awaiting install-
    On Order-
    jlwrangler.com
  5. #5
    Join Date
    Feb 2015
    Location
    Italy
    Posts
    408
    Thanks, understood.
  6. #6
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    21,208
    ^^^ Totally agreed. The track bar has a lot of force at both ends. You want the brackets to be strong. I wouldn't install a Teraflex one even if it was free and came with a personal favor.
    Help support WAYALIFE by purchasing parts here: https://wayalife.com/forumdisplay.ph...eep-Parts-HERE
  7. #7
    Caught the Bug PHX JK's Avatar
    Join Date
    Feb 2016
    Location
    Arizona
    Posts
    86
    Installed the Currie Currectlync Steering with flipped Draglink
    This stuff is really Beefy. I used a 7/8 Irwin Step Bit and was able to drill the right knuckle without Drama.
    I considered the EVO Drag Link Flip which would have saved me about 400 but couldent resist the Beef of the Currie
    Links and the very Stout Weld-On Synergy Weld-On front track bar Bracket.
    For a bit more than 300 bucks I think the EVO Flip is an Exceptional Value. I will not have the Track Bar Bracket welded on till next Week
    Attached Images Attached Images
    If you don't have a plan for yourself someone has one for you!!!
  8. #8
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    45,315
    Thanks!
    A dropped pitman arm will correct the geometry of your drag link angle. A track bar relocation bracket will correct the geometry of your track bar. BOTH need to be installed at the same time IF you are running a tall enough lift to warrant geometry correction.
    That being said, a DRAG LINK FLIP is a better solution than a dropped pitman arm as it will correct geometry from the axle and without putting more leverage on your sector shaft. Also, a track bar relocation bracket that is welded onto your axle is a better solution than one that is dropped from the frame as it will be a stronger setup.
  9. #9
    Join Date
    Feb 2015
    Location
    Italy
    Posts
    408
    Thanks! I decided that EVO enforcer kit with EVO drag link flip kit would be the best choise...
  10. #10
    Nothing but a Thing Andy5160's Avatar
    Join Date
    May 2016
    Location
    New York
    Posts
    2,389
    We have a winner!!!!!!!!!!!!!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
