Quote Originally Posted by Samuelh3 View Post
I have the same problem on my daughters 2001 TJ and am in the process of replacing much of of the steering components, tie rod, ball joints, etc. They needed to be replaced anyway as they are all original. The steering box is leaking quite a bit, could this really be the culprit? What exactly should I be looking for in the gearbox?
A leak won't cause death wobble but if sector shaft has play, that could. Watch it for rocking/popping while someone turns the wheel. The sector shaft is at the bottom of the gearbox and the pitman arm attaches to it.
