Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Death wobble
  1. #1
    Fresh Catch
    Join Date
    Mar 2017
    Location
    US
    Posts
    2
    Death wobble
    Hey guys I have a 2005 Rubicon running a 2.5" lift. I've replaced all tie rods and tie rod ends, track bar, steering stabilizer and I'm still having issues when I hit bumps at high speeds. Thoughts? Thanks!!
  2. #2
    Old Timer black pearl's Avatar
    Join Date
    Dec 2016
    Location
    Sonoma
    Posts
    4,221
    Have you checked your ball joints?
    Take what you can! Give nothing back!
  3. #3
    Fresh Catch
    Join Date
    Mar 2017
    Location
    US
    Posts
    2
    Yeah everything looks good
  4. #4
    Nothing but a Thing 10abadilla/jk's Avatar
    Join Date
    May 2016
    Location
    Santa Ynez, CA
    Posts
    1,345
    If you have checked your ball joints and those have no play. Check your track bar.
    Sent from my LG-H900 using WAYALIFE mobile app
  5. #5
    Join Date
    May 2016
    Location
    Santa Ynez, CA
    Posts
    1,345
    I'd honestly say it's going to be your lower ball joints especially if they are stock. If by some chance they are not. I'd say it might be your track bar frame side bushing shot.
  6. #6
    Nothing but a Thing ob_tj's Avatar
    Join Date
    Dec 2015
    Location
    NorCal Stanislaus county
    Posts
    1,131
    I used to get death wobble really bad in my tj also. Like you I changed out and replaced a whole bunch of stuff. Only to still get it. As crazy as it may sound after I switched from 15s to 17s with new tires it was gone. Ask the guys at the shop and they said it could have been a balance thing. My tires had huge chunks missing and my wheels also had big areas of rock rash that could have been throwing it off.
  7. #7
    Join Date
    Dec 2016
    Location
    Sonoma
    Posts
    4,221
    DEATH WOBBLE : What it is, What it isn't and What You Can Do to Fix it
    https://wayalife.com/showthread.php?t=311
  8. #8
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    28,732
    Stop throwing parts at it and find out what it is. Have someone turn the wheel while you watch the steering parts and track bar. Especially watch the track bar ends. If they move, you could have wollowed out bolt holes. Check unit bearings, steering gear box, and pitman arm splines.
    Jeep JT GLADIATOR FORUM: www.JT-Gladiator.com
  9. #9
    Knows a Thing or Two Samuelh3's Avatar
    Join Date
    Apr 2017
    Location
    Southern California
    Posts
    746
    Quote Originally Posted by WJCO View Post
    I have the same problem on my daughters 2001 TJ and am in the process of replacing much of of the steering components, tie rod, ball joints, etc. They needed to be replaced anyway as they are all original. The steering box is leaking quite a bit, could this really be the culprit? What exactly should I be looking for in the gearbox?
  10. #10
    Banned XJADDICTION's Avatar
    Join Date
    Oct 2016
    Location
    TN
    Posts
    360
    Get her in the jeep and move the steering from lock to lock while engine running(watch out for the fan).
    -Trac Bar loose?
    -ball joints shot?
    -caster off? ( that's an adjustable control arm fix)
    - maybe tires and balance (look for packed mud behind the wheel)
    - steering box mounts loose?
    - play in steering box?
    That about sums it up. I am sure others will add to it if necessary.
    Good luck.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
