Can't decide 4.88 vs 5.13 with 35s on Dana 30
lesterjanpearson
So I read a bunch forums but still undecided. I am running nitto 35s with 20x12 on my sport 2016 A/T on Dana 30, sorry not 33 typo, planning to maybe change to 37s someday.
I spend most of the time on pavement/highways until weekends. im still on stock gears with my sport 2016. getting annoyed
with the constant downshift. Suggestions would be nice. should I go 4.88 vs 5.13? I trust this forum so much. so I better hear
out people here.
madstiles
4.88 max ! You don't won't to go 5.13 your ring gear will be to small and become a weak link assuming you have a dana 30 (post says dana 33?) And haven't upgraded your front axle.
DWiggles
Sorry typo. fixed the post but can edit the title.
Pinion... The PINION will be dangerously small...
for a D30, 4.88 is really the deepest logical gear choice.
AdrockTT
Pinion a real concern...but also!
W 35's on the highway and 5.13s you'll be spinning the crap out of your drivetrain to go 70+MPH. Unless you trailer this thing, I wouldn't advise 5.13s on 35s as RPMs will be really high. Can't imagine the transfer case and other rotating components like this long term...
J
JKDream
Guest
The difference between 5:13's and 35's and 37's is like 200 rpm. His drivetrain wouldn't suddenly fall apart lol.
To the OP - I did 35's and 5:13's for quite awhile, while I had a lot of power it did feel overgeared.
I also feel overgeared on 37's though. I would be considering either 4:56 or 4:88 - not 4:88 - 5:13.
You likely have 3:21's, so even 4:56 is a substantial upgrade.
5:13's are weak on a Dana 30 - that is quite known. Have people done it? Yes.
It all depends on your driving style. I would strip the ring gear within a couple trips, you might not, who knows.
notnalc68
That dude from Mississippi
That's a matter of opinion. I'm running 4.88 in a 2014 auto on 35s. Can I run 37s? Yes. I'd rather have 5.13 with 37s, though, and no way would I want 4.56 for either tire.
AdrockTT
I did not imply it is going to implode or something, but I do think there's driveline stress, less efficiency, and in general it's just too deeply geared for a 3.6L on 35s (unknown to what degree they're worn, what they measure out to, etc.) and 5.13s if you plan any highway time.
For the record - I run 5.13s with 40s...RPMs at 75 are prob 2700ish. I will have to look at exact numbers on my tuner next trip.
J
JKDream
Guest
Correct, it is. I have personally run all three gear sets on both tire sizes with an auto. They're all doable, and an upgrade regardless.
I do quite a bit of highway miles out to trails, and everywhere in between (my JK is a daily as well currently).
5:13 is more of a performance gear set in MY opinion. I would rather be running 4:88 right now.
That's odd, because I have the same RPM's as you with 37s. 5:13's and 35's I was around ~3000 at 70mph, which really isn't bad.
My motor/transmission didn't feel strained at all, if anything it ran better and less sluggish than it did with any other gear set.
This is all heresay though, because personally I wouldn't run that gearset on a Dana 30, I would still recommend 4:56 or 4:88.
notnalc68
out people here.
Ultimately, if you are keeping the Dana 30, then weld on C-gussets, gear to probably 4.88, & run it until it breaks.
