Jk control arm bracket damage
NastyNate
So while wheeling this weekend at hidden falls I had a disagreement with a ledge.....I think it won LOL does this look ok to you guys or should I replace it . Also think I bent my control arm some IMG_6244.jpg
Any input would be appreciated
J
JKDream
Guest
So while wheeling this weekend at hidden falls I had a disagreement with a ledge.....I think it won LOL does this look ok to you guys or should I replace it . Also think I bent my control arm some View attachment 265555
This is after I bent it back some View attachment 265556
As long as the welds aren't cracked at the frame it's good to run. Mine have the same type of damage.
Normal operating characteristic of using a Jeep the way it was intended.
To find out if the arm is bent, measure from bolt to bolt, then compare that measurement to the arm on the other side. They should be the same.
OverlanderJK
Resident Smartass
You may want to remove the arm and try and bend out the bracket just to prevent squeaking and in case it needs to be removed in the future. It'll be easier to do in the garage than on the trail.
DWiggles
As overlander said, I would pull the control arm out and get a prybar in here to clearnace this back out to avoid future issues and inspect the welds closely for cracking... but aside from that... Looks like a good time was had by all... jeeps are like dogs, they LOVE belly rubs. :beer:
