wickedrebel90
Ok, so I've looked at a few threads and elsewhere online, but can't find anything specific to my potential project. I have a 2008 JK and the cats have gone bad. I've replaced the O2 sensors on both the upstream and downstream and its still throwing codes. Instead of buying a new pipe with the converters on it, would it be possible to replace the pipes and install a single catalytic converter? My theory is that if I get a catalytic converter that matches with the 3.8L engine and relocate the O2 downstream sensors after the cat on the single pipe, it should work. Would this be a valid option or a waste?
