After Market Switches, Wiring and Relays
USOWEN
just want to see what everyone does with their wiring for lights and stuff.
I have an inverter mounted under my driver's seat using a premade harness I got from wish. I'm about to add two sets off lights and wanted to see something cleaner before I add more harnesses.
any pics are appreciated!
Sent from my ONE A2005 using WAYALIFE mobile app
OverlanderJK
Resident Smartass
If you only ever plan to use lights rough country makes a panel but it's not rated for anything else. Otherwise, as stated, painless or switch pros. Both have pros and cons.
Yup, Painless makes a great kit that I would highly recommend and they help support WAYALIFE. Switch Pros also makes a great kit.
JAGS
I use the switch pros. It's good for what it is and not overly expensive. Though convenient, I haven't been able to get the Bluetooth function to work as I want.
I didn't install the main unit, but have wired up some lights and that part is super easy.
As others have said. I think there are plus and minus for all these wiring choices.
Frydaddy
If youre good with a wire crimper, I say you could build something as custom as you want. Ive got more documentation, but here's a summary.
Those switch blanks can be turned into actual switches
Bussmann fuse blocks are awesome! (my wire routing, is not. At least everything is hidden.)
A little planning goes a long way...
Rear power outlets. (the inverter is bigger now.)
Rear lighting, antenna, and brake light on an extendable platform.
Frydaddy
Rear light/antenna/brake is really sharp! Thank you for posting!
Though not exactly electrical, I recently added true onboard air, and running water to my rig.
There is a connection front and rear with an air chuck, and a garden hose fitting.
The pumps are mounted in the cavities behind the brake lights, to save space.
And the air tank is metal-strapped under the cabin, the water tank is the rear bumper (for now) that holds about 8 gallons.
