Page 57 of 65 FirstFirst ... 7475556575859 ... LastLast
Results 561 to 570 of 649
Thread: The Adventures of Fiona - '08 JK Rubicon 2-Door
  1. #561
    Old Timer Jsouder53's Avatar
    Join Date
    Aug 2017
    Location
    Gallatin Gateway, Montana
    Posts
    3,603
    Hopefully all is better! I’m sure that did the trick by the sounds of the crap coming out lol
  2. #562
    Addict BaddestCross's Avatar
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    5,417
    Quote Originally Posted by Jsouder53 View Post
    Thanks, I sure hope so. After spending a bunch of time chasing an overheating problem with my work van, I'm over it. Crossing my fingers that this will be a simple fix on the Jeep.
    Build Thread: The Adventures of Fiona
    '08 JKR Rescue Green 2-Door
  3. #563
    Old Timer fiend's Avatar
    Join Date
    May 2017
    Location
    SoCal
    Posts
    3,455
    Thought you were at defense mine today?
    Hope your heat issues are in the past.
    We need to roll soon so I can get you those mirrors.
  4. #564
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    5,417
    Quote Originally Posted by fiend View Post
    I was planning on it, but had to work. Even if I didn't, I would've bowed out because of this heat issue. Since at idle was when it reared its head, I figured crawling wouldn't be a good idea.
    We definitely have to get together and hit the rocks soon... When will you be able to get a free Saturday?
  5. #565
    Nothing but a Thing jdofmemi's Avatar
    Join Date
    Mar 2018
    Location
    Menifee CA
    Posts
    1,853
    I hope it is sorted out now. Got my fingers crossed for you.
    We are overdue for a run. Missed you on the last one.
  6. #566
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    5,417
    Quote Originally Posted by jdofmemi View Post
    Thanks. Same here. I was really bummed to miss it last weekend.
  7. #567
    Been Around the Block Ruvicon's Avatar
    Join Date
    Jun 2017
    Location
    Turlock, CA
    Posts
    323
    Did you check both sides particularly the engine side of the radiator? You could have debris or mud in there. Is the condenser clear?
  8. #568
    Join Date
    Mar 2018
    Location
    Menifee CA
    Posts
    1,853
    Quote Originally Posted by Ruvicon View Post
    Has it even been in there long enough to collect anything like that?
  9. #569
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    5,417
    There's nothing blocking the fins... I haven't even run through any mud or anything to be concerned with. I was talking about the internals... There was junk inside that was probably from the heater core. I flushed everything until the water was clear.
  10. #570
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    5,417
    NOTE TO SELF: 122k Miles
    Well, after almost 4 years, I figured it was finally time to spoil Fiona with some new (yes, NEW, Kirk. Install your fucking lift already! &#128526 tires. She's earned it. I've beaten the hell out of her and she always gets us home... Sometimes with a little help (thanks again, Vic and everyone for the radiator debacle), but she's gotten us home nonetheless. 😎
    After running used Nitto Trail Grapplers in both 35s and 37s, I wanted to go a bit wider and didn't want to deal with the B51 sound of the Mud Grapplers. So, with a bit of encouragement from several members (except you, Greer &#128540, I decided to go with the Cooper STT Pro 37x13.5s.
    With help from Matt at Discount Tire Direct and the good folks at a local America's Tire, we made it happen in a day and for a price that couldn't be beat... thanks guys! 🍻
    Initial impressions... The positive: They look awesome! 😂 I do like how the extra width makes Fiona look a lot more planted and it should help her feel more stable on the trail. They're quiet. Now, those of you that actually saw my last set know that they were really torn up, so anything would be an improvement. Between the road noise and wobble from being unbalanced, I could barely hear the radio at full blast. I obviously haven't taken them on the trail yet, so I can't speak to performance.
    The cons: I aired down to 28psi where I'm used to keeping the Nittos on the road... On the highway, it almost feels like I'm driving on marshmallows. Not sure if it's because of a softer compound or softer sidewalls, but I'll probably air up to 32psi to see if that feels any better. I have to look at the speedometer more than before now... My old tires used to get a major wobble around 60mph and an odd vibration around 80mph. Those are gone now, so I've gotta figure out another landmark. 😂 Probably the thing that threw me off the most was how much weight the took too balance. Anywhere from 7-11 ounces on each tire... Not a fan.
    I'm hopefully gonna be able to hit the rocks this weekend so I'll be able to better tell how they perform... Looking forward to a new adventure.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
