Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: The Hoon Chronicals: Help With an 85 CJ-7
  1. #11
    Addict jesse3638's Avatar
    Join Date
    Sep 2012
    Location
    Apple Valley, CA
    Posts
    5,454
    Well he was back on the road until Monday evening. When he returned to work and went to start it, it fired up and stalled several times. He applied a little throttle and it backfired then continued running. While on his way home he lost power and it then stalled and could not be restarted. He had it towed home and that is where is currently sits. The previous owner had it converted to fuel injection. I'm not sure as to the system which was installed. First thought which comes to mind would be fuel filter and/or fuel pump. Any ideas as to where to begin would be appreciated. Thanks!
  2. #12
    Nothing but a Thing Strodinator's Avatar
    Join Date
    Apr 2017
    Location
    Oregon
    Posts
    1,142
    Quote Originally Posted by jesse3638 View Post
    First thing would be to spray starting fluid into the intake. If it fires right up and then does after burning it up then after checking all the injectors, trace the lines all the way back to the fuel pump to check for leaks. If you still havnt found it then check for voltage at the pump and pull the pump. I had the same thing wrong with my TJ and with the pump out sitting in gas, when I primed the pump, it would whirr but not send fuel to the hose.
    Sent from my Life One X2 using WAYALIFE mobile app
    If you want to see a broke college kid struggle through an LS swap, then here's your chance: https://wayalife.com/showthread.php/...546#post956546
  3. #13
    Join Date
    Sep 2012
    Location
    Apple Valley, CA
    Posts
    5,454
    Quote Originally Posted by Strodinator View Post
    I thought the 85 came stock with a mechanical pump and I'd assume since it was converted to EFI it would need to have been switched to electrical. Do you think is a correct assumption?
  4. #14
    Join Date
    Apr 2017
    Location
    Oregon
    Posts
    1,142
    I would think so yeah. Just check off the easy things. Spark plugs, spark plug wires, battery, alternator and then start at the intake and move back to check if it's the fuel system.
  5. #15
    Join Date
    Sep 2012
    Location
    Apple Valley, CA
    Posts
    5,454
    Now he's talking of selling it. If he offers the right price I may take it..haha
  6. #16
    Addict Brute's Avatar
    Join Date
    Nov 2015
    Location
    HI & WA
    Posts
    7,165
    Sounds like a conflict of interest...
  7. #17
    Join Date
    Sep 2012
    Location
    Apple Valley, CA
    Posts
    5,454
    Quote Originally Posted by Brute View Post
    For who?.... He had a mechanic buddy come over and determined it was the fuel pump. That will be on his to-do list.
  8. #18
    Join Date
    Sep 2012
    Location
    Apple Valley, CA
    Posts
    5,454
    Well he's having issues with it again. An 87 CJ probably wasn't a wise choice for someone without the time or ability to troubleshoot and make necessary repairs. He's thinking of selling it again. I'll keep everyone posted so if anyone is looking.
  9. #19
    Old Timer Jsouder53's Avatar
    Join Date
    Aug 2017
    Location
    Gallatin Gateway, Montana
    Posts
    3,570
    That’s a sad moment, definitely a good idea to have some sort of knowledge about Jeeps to get involved in that sort of project...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
