Close
Results 1 to 7 of 7
  1. #1
    Caught the Bug Samuelh3's Avatar
    Apr 2017
    Southern California
    67
    Steering components rebuild on TJ
    So I'm looking to replace most of the steering components on my daughter's TJ. I've been looking at the kits from Quadratec. Is the Crown Automotive brand a reliable one or should I be looking elsewhere?
    Also I need to replace (or rebuild) the steering box as it leaking like crazy. Hoping to find a rebuilt one for cheap. Any thoughts on how hard it is to replace the seals on this part? I see a seal kit and according to Quadratec its an "advanced" operation.
  2. #2
    Hooked Snboarder113's Avatar
    Oct 2015
    michigan
    122
    Quote Originally Posted by Samuelh3 View Post
    Ive used crown components, they're pretty much OEM, someone can correct me if im wrong there. As far as the leaking Steering gear, super common, not worth playing with imo, TJ replacement ones are often pretty pricey, however it is the exact same one thats in all ZJ models as well and can be had super cheap that way. There is also a dodge durango gear- maybe only the v8? would have to look it up- that is an "upgrade" piece as its a direct bolt in and is more powerful. Good luck fixing all the rust, I've heard good things about Eastwood Chassis Saver treatment / paint.
  3. #3
    Caught the Bug John82601's Avatar
    Jul 2014
    Casper, WY
    51
    Agreed, Crown is essentially O.E. quality and generally a fine product. Changing out the seals on the steering gear is definitely a viable option if it works fine otherwise. An alternative would be a reman from someone like Rock Auto, $200ish for one.
    Direction, then velocity.
  4. #4
    Apr 2017
    Southern California
    67
    Project went on without a hitch. I was able to replace the tie rod and drag link with no real issues. The ball joints still need to be replaced along with the steering gear box which is puking oil like crazy but so far so good. I haven't measured the toe-in but she drives straight as an arrow and with no issues.
    The packaging from Quadratec left much to be desired but all the parts were there and had no damage.
    My biggest concern was with all the rust underneath. I soaked all the bolts with PB blaster and let it sit for about an hour. I got pretty lucky and they all came of relatively easy. Love my impact wrench!!
    Reassembly was a piece of cake. I measured as best I could the drag link and tie rod and made the new components match and started putting it all back together.
    All in all is was a relatively easy project. Now onto the ball joints and steering box! After which I may replace the brake drums/rotors as they seem pretty worn and rusted.
  5. #5
    Nothing but a Thing Andy5160's Avatar
    May 2016
    New York
    1,806
    Good job and this is one rusty under jeep where is it from originally? Does not look CA jeep to me.
    Something you would have to address if you plan to keep the jeep.
  6. #6
    Old Timer JKbrick's Avatar
    Feb 2013
    Leo, Indiana
    3,353
    Just replaced the steering gear on the local barbers TJ, took about an hour. I believe he paid $140 for it at napa
  7. #7
    Apr 2017
    Southern California
    67
    Quote Originally Posted by JKbrick View Post
    Yup I was able to find a rebuilt one for $140 at AutoZone. We'll see how it holds up. So far so good.
