Traction control on immediately when in 4L
DanJK2007
Newbie here. I have an 07 Wrangler, lifted. Anytime I switch to 4L, my traction control light immediately comes on along with my 4W light? Any insight? It doesn't do it when in 4H? Thanks guys
rumblebee3
Welcome to WAYALIFE 👋 stop by and give us a wave.
When you put your Jeep into 4 Low it automatically turns the traction control system off. 4 high it does not do this
cozdude
Guy with a Red 2-Door
It's never fully disable but the light will come on. It's totally normal as mentioned
Frydaddy
Is that why even in 4 Low the traction control still freaks out every now and then? Or maybe it's just me LOL
there is a way to bypass all that traction control stuff. If you ever need it to be completely off, Take apart your center console and splice a switch to the Purple wire with the Light Blue stripe. Leave the switch ON when on the highway, then flip it OFF when on the trail.
(Disclaimer: Only to be disabled when on the trail)
rumblebee3
That is very good to know thank you.! I love the disclaimer LOL
cozdude
Not sure why you would want to fully disable to traction control when on the trail. The TC kicking in helps so much if your wheeling without lockers on your rig or without them engaged. It acts as a limited slip which is very helpful
madstiles
Or pull the pump fuse
Frydaddy
I said IF ...
Doesnt that kill ABS too? And something else I dont remember.
jknikos
Disabling your electronics totally will disable your bld (braking lock differential) too. Bld acts as a lsd and will provide a lot of help if you dont have lockers.
Sent from my LG-D855 using WAYALIFE mobile app
