I would say throw out bearing, if it did it all the time when the Clutch is depressed. Is the clutch fully disengaged when you depress the clutch pedal to the floor?
Only when stopped leads me to think the clutch may not be disengaging totally.
I'm unfamiliar with that clutch system. Is there an adjustment? Hopefully somebody with more knowledge on this particular clutch system will provide some details.
If its still the original clutch and pressure plate, there's probably a good chance that the springs are starting to drag on the flywheel when they're not totally locked together yet...which would make sense as to why the noise goes away once youre up to speed.
Sent from my Pixel XL using WAYALIFE mobile app
When it happened I was exiting the highway and came to a stop light on the road. The jeep didn't want to go in gear, I had to force in it, that's when the noise started. The jeep has been parked since it happened. Just trying to get some info before getting parts...
Well if it was from a stop and the clutch was engaged, the only things that would keep it from going in to gear are either the clutch spring is shot (and the pressure plate is dragging and thus the clutch is actually still engaged, even with the pedal depressed), the clutch hydraulics are going and thus clutch was actually catching ( and slipping) or a synchro is shredded. My bet would be the clutch disk/pressure plate is coming apart and catching. How many miles are on it?
