Evap code
Al Gore will be furious. The rest of us will go about our normal business in life. You have a fuel vapor leak. Could be as simple as a loose gas cap. Could be other things too though.
jkrichard
Just dealt with that as well a few months ago. Needed a new fresh air filter and that little check valve on the evap canister. I had another code too and was periodically getting the gas cap light come on. Was an easy fix, took longer to try to convince the dealership that the evap canister has a fresh air filter...
Sent from my SM-G955W using WAYALIFE mobile app
Arrcherr
This is not my write up this is just the one I used to get my evap issue fixed. I thought he did a great job with it and figured I'd share it to see if it helps.
Jeep jk evap error fixes found
All, I just wanted to share what I found through trial and error and lots and lots of searching this forum, other forums, and online in general. I've had EVAP (Evaporative Emission System) leak error codes (P0455, P0456, P0457 or the GAS CAP message) multiple times over the past couple of years that finally annoyed me enough that I decided to launch a quest to fix it. That quest started with a trip to the service department but ended in me taking charge of finding the solution myself. Below is what I learned in hopes it may help someone else.
Bottom line, it's obvious Jeep's EVAP system isn't rock solid - problems are all too common. Personally, given I believe EVAP systems to be a bunch of hog wash to begin with, I wish there was a way just to pull the system out and be done with it. You could certainly do that, but I don't know of a good way to fool the computer into not throwing a big light up on your dash and codes in the system. If someone knows how, post it - I'm sure there are folks that might prefer to give it a try versus fixing it, particularly if they're beating their Jeeps on the trail, as the EVAP system is a delicate beast.
Codes: Below are the codes your computer will usually show if you have EVAP leaks.
- P0455 - EVAP system error (gas cap or other)
- P0456 - Small leak detected
- P0457 - Large leak detected
OEM MOPAR Part Numbers for items listed in the diagnostic section:
Gas Cap: 52100552AG (MSRP: $22)
EVAP Canister: 4891781AB (MSRP: $63)
EVAP Leak Detection Pump: 4861962AA (MSRP: $35)
EVAP Leak Detection Pump Gasket: 52129436AA (MSRP: $5)
Purge Valve: 4891731AA (MSRP $20)
Clearing Errors:
You can clear your gas cap message but clicking the little odometer reset button in the dash. Of course, if the issue still exists, it'll come right back next time you start the Jeep. You can also get multiple codes from the above list, and when you do, your odometer will be twice the brightness along with a nice little orange engine light in your dash. You'll need to connect an ODBII reader to read the codes and reset if desired. (You can also clear it by unplugging your battery, but again, if the problem still exists, it'll come right back within 50 miles or less, usually less)
Diagnostic/Fix Recommendations IN ORDER:
Step 1. First and foremost, change your gas cap. Yes, it sounds like bologna, but many, many issues are in fact a bad seal on the gas cap. When you do this, DO NOT use an aftermarket gas cap. I'm not saying it won't work, but you're in troubleshooting mode right now, and the OEM Jeep gas cap is cheap, and you can depend on it sealing properly. Once your issues are taken care of, that's the time to get that fancy billet aluminum gas cap if you want it. If this doesn't fix it, move to step 2.
Step 2. Check your EVAP canister. The EVAP canister is a black box on the underside of your carriage, just left of the gas tank. It has two plastic hoses coming out of it. It is totally unprotected, and if you like to offroad, it's super easy to bust it/crack it. It's a hunk of plastic with charcoal in it. Some people choose to relocate it, and many aftermarket folks make skid plates to protect it. If it's broken or cracked or the plastic hoses look messed up, replace it. It costs around $30-$40. If you do replace it, MAKE SURE YOU HAVE A GOOD GASKET. There is a little green gasket between the EVAP canister and the little white box (EVAP Leak Detection Pump) attached to it. This gasket is critical - otherwise, it will leak. I personally put a little bit of silicone grease on the gasket to ensure it has a good seal. If you loose it or the gasket isn't in good condition, replace it. No dice? Move to Step 3.
Step 3. Check your hose near your battery. There is a black plastic hose that runs to your Purge Valve (a part of the EVAP system) that runs directly next to the right side of your battery. In fact, it touches it, and many folks have issues with the back side of this plastic hose corroding/rubbing till it causes a small pinhole. Feel the hose, particularly the part of the hose touching the battery. If it's rough and not smooth like the rest of the hose, you can temporarily and tightly tape it with electrical tape or replace that section. You can replace it with good quality fuel hose obtainable at any parts store, or you can even get short replacement EVAP lines with rubber ends from places like AutoZone for just this type of thing. I found a nice generic one from AutoZone that worked perfectly for mine. Still no dice? Move to Step 4.
Step 4. Replace your Leak Detection Pump. This little pump is what basically helps the computer determine if there is a leak. The pump is not exactly bullet proof in design of operation or longevity, and it's a VERY COMMON issue that it doesn't work properly causing a false alarm on EVAP leaks. The pump is cheap enough that if the above hasn't worked, I would replace it before moving to steps 5 and 6. Still no go? Try Step 5.
Step 5. Inspect all of your EVAP system parts and lines/hoses. Do this with your fingers feeling for loose connections and any holes or roughness in the lines/hoses. Also inspect very closely with your eyes and a really good, strong flashlight. See any bad hoses? If so, replace them. You can splice in a good quality 3/8" fuel line or buy the OEM replacement hose. If you use fuel line, just make sure you have a good firm connection and use a good setup of hose clamps for a quality seal. Still no dice? Move on to Step 6.
Step 6. Replace your purge valve. Cost of this part isn't great, so you could choose to replace it and give it a try. If you don't want to try that, you can test it by applying 12v to the incoming leads - it's basically a valve. You can blow into it, and apply voltage, then not blow into - if that's the case, it's probably working. It could still have a leak potentially, but that's the basic operational test. If you don't want to try replacing it, or if you feel confident it's working and not got a leak in it, then move to Step 7.
Step 7. You have arrived at the Smoke Test. You can hire your local shop to do this test or do it yourself. Basically, you send smoky air through the EVAP system, grab a strong flashlight, and look for a leak very carefully. Professional smoke test machines are commonly used to diagnose EVAP system leaks in all modern vehicles that have these blasted abomination EVAP systems. Unfortunately, these machines run about $2,000. If you're a stubborn do it yourself kinda guy like most Jeepers are, you can actually make your own for less than $50. Basically, you get a new metal paint can, pipe up some hoses in and out of it, hookup the incoming air line to a propane (low pressure) regulator you can buy at your hardware store, then hook the regulator up to your shop air compressor. Light some incense sticks inside of the paint can, seal the lid, hook the outgoing hose up to the line attached to the purge valve, and search for leaks. (The purge valve is located in front of the battery) There are plenty of youtube videos that show you exactly how to build these and use them. (Search for "DIY smoke tester" on youtube) If you're at this point, you're really out of quick and easy options. You're gonna likely have to do this or get it done to identify the root issue. Good thing is, it's doable, and if you have a leak, with enough time, you'll find it.
What was causing my error codes? My gas cap wasn't sealing every time, and I did have a corroded plastic hose due to rubbing up against the battery. However, I still had error codes after addressing those issues and replacing my EVAP canister. My fix was to replace the leak detection pump. Once I did that, she's been error free since, and I'm crossing my fingers it stays that way.
Good luck!
DanJK2007
Clearing Errors:
Good luck!
Wow this is awesome . Thanks for the help man. Way more information than I would have ever thought to get! Hopefully I’ll fix it soon! I’ll pass the knowledge as well if anyone else has the issue.
Arrcherr
Glad I could be of some help[emoji106]. Like I said though I can only take credit for copying and pasting. The hard work on the write up was from someone else.
Good luck with the fix!!
Jace817
I just went through this too. Wasn’t the pump. Just tried the canister. Appears to have fixed it. Knock on wood.
