Results 1 to 3 of 3
Thread: Alignment after 1.5” lift
  1. #1
    Fresh Catch
    Oct 2017
    US
    2
    Try to make a long story short - recently went with the same setup the Wayalife Renegade is using (rims, tires, lift, and 1.25” spacers). I had an alignment done the other day, but my steering wheel is just off to the left. The place I went to said they did all they could do. Other shops were saying the camber kit and adjustments are all maxed out and they’re unable to do anything else. Can anyone assist me with this?
  2. #2
    Meme King WJCO's Avatar
    Sep 2015
    Colorado
    28,806
    I don't see how the 2 would be related, but I haven't lifted a Renegade, I would assume the toe angle would need to be modified to correct that but not sure.
  3. #3
    Sep 2015
    Colorado
    28,806
    Looking at the pictures in the lift install write-up thread, this thing has a rack and pinion. You should be able to center steering wheel, then adjust toe properly and steering wheel will stay centered. That's how nearly every rack and pinion vehicle is adjusted, I can't see this being any different.
Similar Threads
  1. Alignment after lift
    By Sugarbear in forum Jeep JK Wrangler
    Last Post: 08-23-2015, 05:14 PM
  2. Alignment?
    By srosario in forum Jeep JK Wrangler
    Last Post: 03-20-2015, 09:12 PM
  3. Small lift, alignment
    By MedixJK in forum Jeep JK Wrangler
    Last Post: 11-20-2014, 05:41 PM
  4. Alignment is off already!
    By Jeep_Will in forum General Jeep Stuff
    Last Post: 09-18-2014, 02:55 AM
  5. Alignment after lift, Thrust is off - how to correct
    By wwood in forum Jeep JK Wrangler
    Last Post: 10-08-2013, 02:59 AM
