Results 1 to 6 of 6
Thread: Needed 2” rear bump stop extension
  1. #1
    Been Around the Block whytiptoe's Avatar
    Oct 2012
    Gallatin, Tennesse
    491
    I already have 3” on my 16 JKUR but they are to tall and I have more than enough wheel well to go further.
    Why Tip Toe Thru Life To Arrive Safely At Death
    2016 Hydro Blue JKUR HR
  2. #2
    Old Timer VeruGE*144's Avatar
    Feb 2017
    Illinois, Chicago
    2,736
    You need to make sure you won’t over compress your shocks before decreasing your bumps, no matter how much wheel well space you have.
  3. #3
    Oct 2011
    Carson City, NV
    47,132
    Quote Originally Posted by VeruGE*144 View Post
    This ^^^
    Definitely want to run as much coil spacer as you have lift to help prevent over compression of your coils.
  4. #4
    Oct 2012
    Gallatin, Tennesse
    491
    Thank you and totally get that as well. Wish I had the photo to show you what it looks like with bump stop completely compressed.
    Attached Images Attached Images
  5. #5
    Addict hinrichs's Avatar
    Nov 2012
    Wyomissing, PA
    5,476
    looks like you still have room to compress in that picture
  6. #6
    Been Around the Block Samuelh3's Avatar
    Apr 2017
    Southern California
    491
    The rear bumpstop isn’t fully compressed. Make sure your not bottoming out your shocks as you’ll damage them over time. You’ll want to have just a touch of travel left on the shock to prevent it from bottoming out completely. If this is the EVO kit or similar 3” should be ideal. You’ll still have room in the wheel well but the shock will be pretty close to being fully compressed.
Similar Threads
  1. King front and rear bump stop PSI
    By whytiptoe in forum Jeep JK Wrangler
    Last Post: 11-06-2017, 11:29 PM
  2. Too much bump stop?
    By Keggerbombs in forum Jeep TJ & YJ Wrangler
    Last Post: 11-18-2016, 03:41 AM
  3. Spare tire bump extension
    By Heavyhaul07 in forum Jeep JK Wrangler
    Last Post: 10-25-2016, 03:57 AM
  4. Replies: 5
    Last Post: 05-25-2015, 02:50 PM
  5. Rear bump stop replacement, OEM alternative?
    By Tumbleweed in forum Jeep JK Wrangler
    Last Post: 11-06-2013, 03:33 PM
