Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
Thread: HOW to GET to the NIPPLES - Front Lower Control Arm Greasing Solution
  1. #21
    Been Around the Block whispike's Avatar
    Join Date
    Oct 2011
    Location
    So Cal
    Posts
    258
    Great write up, I’m going to give this a try! I’ve never greased mine before so do you just fill them with grease until it starts to ooze out or something like that?
  2. #22
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    28,711
    Quote Originally Posted by whispike View Post
    You can watch for grease, but you will also start to feel more resistance in the grease gun.
    Jeep JT GLADIATOR FORUM: www.JT-Gladiator.com
  3. #23
    Living the WAYALIFE JAGS's Avatar
    Join Date
    Aug 2012
    Location
    SoCal
    Posts
    11,160
    So quick question and figured I'd ask here as this thread is near the top.
    Not related to the control arm, but rather the nipple on the joint of my carrier. Seems I got a bit flexed in the rocks and tagged the corner of my carrier. In doing so I broke a zerk. But the threads are still in the joint end.
    Not a huge deal, but wondering the best way to get the end out without fucking up the joint itself? Haven't tried anything yet as it's just the carrier joint.
    I think I may consider lifting my Jeep. Or not.
    The Evolution of ENVY
  4. #24
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    53,551
    Quote Originally Posted by JAGS View Post
    What's left inside shouldn't be tight and you can probably remove it with an easy out.
  5. #25
    Join Date
    Aug 2012
    Location
    SoCal
    Posts
    11,160
    Cool. Was hoping that would be the case. Thanks.
  6. #26
    Been Around the Block JeepDrum's Avatar
    Join Date
    Jan 2014
    Location
    Voorhees, NJ
    Posts
    369
    Is this the same size needle that is used on lower ball joints like Alloy USA? I'm using a needle from a kit I got on Amazon and all the grease just seems to make a mess instead of going into the low profile zerks fitting.
    This is the kit I have:
    Tooluxe 61077L Grease Gun and Lubrication Accessory Kit | Zerk Fittings | Multi-Function https://www.amazon.com/dp/B002RMMXG8..._43tQBbEVN4QMY
  7. #27
    Old Timer TrainWreck618's Avatar
    Join Date
    Oct 2015
    Location
    East of St. Louis
    Posts
    2,915
    Quote Originally Posted by JeepDrum View Post
    Looks like it should work, push harder
  8. #28
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    28,711
    It will work but it has to be centered on the zerk with so pressure applied so the needle is firm against the joint. They're a little tricky. The needle in that kit will work. Just make sure that you aren't using the sharp one pictured below.
  9. #29
    Join Date
    Jan 2014
    Location
    Voorhees, NJ
    Posts
    369
    Ok thanks guys, I'll try again tomorrow. Today I tried two of the needles. Not the one pictured, but the ones with a dull point. Maybe it just wasn't seated right or something. It is tricky. Just out of curiosity, what are those sharp ones for? Poking through a boot and squirting grease in?
  10. #30
    Addict jesse3638's Avatar
    Join Date
    Sep 2012
    Location
    Apple Valley, CA
    Posts
    5,581
    Yes or injecting poultry.
Similar Threads
  1. Greasing Lower Dynatrac ProSteer Ball Joints
    By WJCO in forum Jeep JK Wrangler
    Last Post: 04-01-2019, 03:49 PM
  2. EVO lower front control arms
    By catahoula in forum Off Road Evolution
    Last Post: 02-09-2017, 01:32 AM
  3. Greasing lower ProSteer ball joint
    By MacRubi2 in forum Jeep JK Wrangler
    Last Post: 09-17-2016, 07:22 PM
  4. EVO front lower control arm HELP!
    By Jake Wilson in forum Jeep JK Wrangler
    Last Post: 03-23-2015, 12:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
