Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
Thread: 2007-2011 Jeep Wrangler JK EGR Replacement
  1. #21
    Join Date
    Oct 2012
    Location
    SoCal
    Posts
    31,014
    Quote Originally Posted by Shadow's_Jeep View Post
    I hope you don't have cracked exhaust manifolds, as the exhaust manifold and cylinder head's are supposed to be cast as one unit.
    Sent from my SM-G930V using WAYALIFE mobile app
    Yeah I know that. I’m guessing it’s a head issue but I haven’t gotten a code for the dealer to replace yet.
    2012 Dozer JK
    -Dynatrac PR44/Rubicon Rear
    -Nitto 37” Trail Grapplers
    -Rock Krawler 2.5” Lift
    -ATX Slabs
    -Warn VR8
    -EVO Armor/Bumpers
    2012 Billet Silver JKUR
    -EVO DTD front and rear
    -Dynatrac PR60/PR80
    -EVO High Clearance Long Arm
    -Nitto 40” Trail grapplers
    -KMC Machetes
    -JE Reel 1410/1350 Driveshafts
    -Warn CTI 9.5
    -EVO Armor/Bumpers
    1975 DJ5
  2. #22
    Nothing but a Thing SDG's Avatar
    Join Date
    Apr 2013
    Location
    San Diego
    Posts
    1,525
    Nice write up Tony. That looks like a bitch of a fix!
    '14 JKUR
  3. #23
    Been Around the Block DannyD's Avatar
    Join Date
    Jun 2016
    Location
    Feura bush NY
    Posts
    325
    Great write up I did mine last year and I was ready to put the sawsall on that trans pipe... wish I had this write up
    2009 Red Rock Crystal jk 2.5" lift cooper S/T Maxx's
    1942 willys MB work in progress
  4. #24
    Fresh Catch
    Join Date
    Oct 2011
    Location
    asdfasdf
    Posts
    35
    Looking to change out my egr next weekend. I received my new egr but it didn’t come with new hardware. I’ve spent a few hours looking for the bolt part numbers and found this 6508489AA. I can’t find the part #’s for the 10mm bolts. Would anyone know what they are or the fastener specs?
  5. #25
    Been Around the Block JDDK's Avatar
    Join Date
    Apr 2014
    Location
    Oxnard Ca
    Posts
    361
    just did this change this morning in less than 90 minutes. God bless the saint who did this write up. buy the ratcheting 3 inch mini wrench set from Harbor Freight. it worked perfectly and actually easily. pull the tire and the rear half of the fender liner and an 8 to 10 inch seat is very key. also lossen the little 10mm bolt that holds the dipstick tube. while youre at it, change your sparkplugs. both jobs in less than 2hrs. total. I have been reading and dreading this for 6 months but the forum saved my sanity.
  6. #26
    Join Date
    Apr 2014
    Location
    Oxnard Ca
    Posts
    361
    ok, trying not to lose it...CEL lit up today. engine drops rpm at idle for a second every ten seconds. did I get a bad EGR out of the box? replaced just 3 days ago!
    going to check codes. last time it was the 406...
  7. #27
    Join Date
    Apr 2014
    Location
    Oxnard Ca
    Posts
    361
    p0306 cylinder 6 misfire.
    just replaced plugs and egr. runs great except at idle. Help please?
  8. #28
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    28,089
    Quote Originally Posted by JDDK View Post
    If you removed the plug wire when you did the egr repair, double check that you got it back on tight. Also make sure it is routed correctly and didn't get burned through on the exhaust nor is it arcing against another wire. Sometimes if you overlap plug wires, they can arc to the one next to it.
    Jeep JT GLADIATOR FORUM: www.JT-Gladiator.com
  9. #29
    Addict BaddestCross's Avatar
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    5,419
    Did you replace the wires and distributer as well? I just replaced mine at 100k (factory recommendation anyway) and my idle smoothed out better than new. I wasn't getting codes, but the idle was rough.
    Build Thread: The Adventures of Fiona
    '08 JKR Rescue Green 2-Door
  10. #30
    Caught the Bug enfielded0405's Avatar
    Join Date
    Jan 2017
    Location
    GA
    Posts
    91
    Got a P0404 2 days ago. Cleared it and it came right back the next day. Looks like I will be changing mine this week or next. Thanks for the write up.
Similar Threads
  1. Replies: 42
    Last Post: 12-11-2018, 07:29 AM
  2. 2011 jeep jk engine replacement
    By Jay_r24 in forum Jeep JK Wrangler
    Last Post: 07-21-2016, 02:49 PM
  3. For Sale 2007 Jeep Wrangler $17,000.00
    By JKDriver07 in forum FOR SALE (Active Members ONLY)
    Last Post: 07-24-2015, 05:15 PM
  4. Jeep wrangler unlimited 2007 Québec
    By Robintibo in forum FOR SALE (Active Members ONLY)
    Last Post: 07-01-2014, 08:32 PM
  5. 2007 Jeep wrangler motor mount
    By Marcosalejos18 in forum Jeep JK Wrangler
    Last Post: 10-14-2013, 02:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
