Page 4 of 4 FirstFirst ... 234
Results 31 to 38 of 38
Thread: 2007-2011 Jeep Wrangler JK EGR Replacement
  1. #31
    Been Around the Block JDDK's Avatar
    Join Date
    Apr 2014
    Location
    Oxnard Ca
    Posts
    361
    checked wires. good. checked obd again. threw a cat converter code now instead of cyl6missfire. wth? befuddled...cleared codes. driving and waiting for cel again.
  2. #32
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    27,972
    Quote Originally Posted by JDDK View Post
    Not uncommon to have a cat code with a misfire because of excessive unburned fuel going into the cat. Swap the #6 wire with one right next to it (switch both ends of each wire). When engine light comes back on, if misfire moves to that other cylinder, then the wire is bad. If not, something else is.
    Jeep JT GLADIATOR FORUM: www.JT-Gladiator.com
  3. #33
    Fresh Catch
    Join Date
    Oct 2011
    Location
    asdfasdf
    Posts
    35
    Just finished egr replacement, plugs and wires. Just want to say thank you for the write up as it made the job a lot easier than it could have been!
  4. #34
    Fresh Catch
    Join Date
    Jun 2018
    Location
    Ottawa
    Posts
    43
    Just finished my EGR valve install. God damn, that was a pain in the ass. The bolts were so seized I almost stripped the head off one. I ended up using the handle of my hilift in order to get more torque, and that definitely helped. I didn't find this write-up until I was trying to unplug the connector...the locking tab was an annoyance I didn't anticipate, so reading that it was a sliding tab was very helpful.
    For those who attempt this job in the future...pull the tire and the fender liner. I didn't, and it caused more trouble than it was worth.
  5. #35
    Join Date
    Apr 2014
    Location
    Oxnard Ca
    Posts
    361
    OK, CEL came back on after replacing egr a few months back. kept clearing it and it was persistent. After repeated hope that oreillys just sold me a bad unit, i bought another one to swap out. Me and that bolt are getting to know each other intimately. oreillys gave me full credit for a return on the old and so far so good. This time I had it out and in around 30 minutes. removed that vent tube and cleaned all the crud out of it too.
  6. #36
    Been Around the Block sm31's Avatar
    Join Date
    Nov 2012
    Location
    Eagle River, AK
    Posts
    283
    Yesterday I had the "dubious" honor of joining the brotherhood of the EGR (2011 JKUR auto)...
    One tip I would add, pertaining to that super hard to reach bolt on the back of the valve:
    For awhile I was fighting with various wrenches, etc. to try and get a good bite on that bolt, all the while being scared to death that I was going to round it off (as many have). I decided a socket would be the only reliable solution but the dipstick tube was too close even after some "coaxing" with a pry bar. Then I noted that the tube is attached to a bracket directly behind the valve. Rather than risk damage to the tube, I was pretty easily able to get a good sized pry bar on that bracket and move the whole thing almost to the firewall. At this point I was easily able to get a flex-head wrench and socket on that back bolt and safely remove it.
    edit: I did use a sizable cheater on the socket wrench.
    Not that it didn't suck but it certainly sucked less. Good luck!
  7. #37
    Join Date
    Nov 2012
    Location
    Eagle River, AK
    Posts
    283
    Well that lasted 3 months. Pretty pissed that I get to become a real "expert" at this apparently. Any recommendations on actual quality parts? Tempted to put this one through the window at O'reilly.
  8. #38
    Old Timer fiend's Avatar
    Join Date
    May 2017
    Location
    SoCal
    Posts
    3,442
    I replaced with an oreilly egr valve. CEL went off for a while, came back on, went off and has stayed off.
    Take a long drive or two and see if it goes off.
Similar Threads
  1. Replies: 42
    Last Post: 12-11-2018, 07:29 AM
  2. 2011 jeep jk engine replacement
    By Jay_r24 in forum Jeep JK Wrangler
    Last Post: 07-21-2016, 02:49 PM
  3. For Sale 2007 Jeep Wrangler $17,000.00
    By JKDriver07 in forum FOR SALE (Active Members ONLY)
    Last Post: 07-24-2015, 05:15 PM
  4. Jeep wrangler unlimited 2007 Québec
    By Robintibo in forum FOR SALE (Active Members ONLY)
    Last Post: 07-01-2014, 08:32 PM
  5. 2007 Jeep wrangler motor mount
    By Marcosalejos18 in forum Jeep JK Wrangler
    Last Post: 10-14-2013, 02:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
