Error code u140a and u0184
rogerk93
About 4 months ago my abs light and traction control light came on and stayed on I replaced my driver side abs wire and it solved the problem for about a day. Both lights came on so I plugged in my superchips and seen it said passanger side was the issue. I replaced the passanger side and the light still is on. I checked my superchips again and these two codes came up u140a (implausible speed signal received right front wheel) and u0184 lost communication with radio. I can’t find anything to fix it. It really doesn’t bother me but would like to solve the problem.
cozdude
Guy with a Red 2-Door
I would still check the hubs. If you replaced the wire and the issues stayed then it will be something inside of the unit itself. Did you change your tire size as well with your super chips? It could be seeing a faulty reading from that as well. Just trying to cover the basis roger
